Thread: Help Damaged ECM
    Jun 2013
    Augusta WA
    Help Damaged ECM
    I have damaged the circuit board trying to install a remap chip in my TD5 aaaaargh.
    I have a spare from a similar year, is it possible to use this and if so what process do I have to follow? I have a Hawkeye.
    Jul 2014
    west of Transylvania
    Hi, first go into EMS - programming - immobiliser and follow the steps as to get the message that the security code was learned then in the injectors menu insert the injector codes, if you dont know them you have to remove the rocker cover and read them from the solenoids
    Jun 2013
    Augusta WA
    Thanks Sierrafery,
    It runs but I have no throttle and M & S lights flashing, any Ideas?
    Jul 2014
    you said it's the same year but it was the same transmission?, is yor's manual or auto...what are the part numbers of the original and replacement ECMs?
    for throttle the driver demand must be set the same like the first one(2 or 3 track) for M+S usually the setting is in BCU for maunal or auto
    Jun 2013
    Augusta WA
    Both Autos. Original ECM MSB 101193 replacement MSB 101340. I also have the engine light illuminated as well as M + S flashing
    After programming shut down the car, unplug
    Lock, wait for 60 seconds and restart
    Jul 2014
    Quote Originally Posted by Pippin View Post
    so the 101340 was removed from a Eu3 modell while your's is Eu2 i think , in EMS programming you'll find the driver demand, set it to 2 track(or way i can't remember exactly) then the MIL and M+S should go away and you can drive it
    Jun 2013
    Augusta WA
    SHE LIVES!!!!!!!!
    Thankyou very much Sierrafery, I don't know what the EU3 ECM was doing in my spare 2001 Discovery, must have been a replacement unless the changeover was earlier than I thought.
    Jul 2014
    the tranzition was at the end of 2001
    Jun 2013
    Augusta WA
    Quote Originally Posted by sierrafery View Post
    Following these steps it now runs very very smoothly, leading me to believe that the injector codes were not re-entered after work was done on the head and the injectors had been mixed up prior to my purchase 9 years ago. It may be worthwhile if you have access to a Nanocom or Hawkeye to re-enter the injector codes, particularly if you know work has been done on the head that necessitated the removal of the injectors.
