Results 1 to 10 of 34
Thread: WTF! - EGT's with TRS chip... Td5 manual MSB
    South Sydney
    Hi all,
    It seems my chip woes are only continuing, this time it hasn't just been slightly annoying, but it's scared the **** out of me!
    Background;
    10p MSB chipped ECU from TRS fitted to my 2001 td5 manual @200,000km's in July 2014. When I bought it they said it was "perfectly safe, just not to labour it in 5th gear when towing". It was fitted at the same time as the 32's and brought performance back... fast forward to March 2015 it has done 30,000km's, (with no issues, apart from my displeasure about the smoothness or rather lack there of, of the tune) the next round of mods is occurring and I fit a TRT boost box, D2a intercooler, silicon hoses and wind the boost out to 19psi. At the same time i fitted boost and EGT gauges, this is where it get's scary...
    The following two photos were taken on the same hill, at the same speed, unladen car, cool autumn day;
    -flat out in 5th gear @100km/h - just pushing past 650, won't climb much higher unless towing.
    -1/2 to 3/4 throttle in 4th @100km/h - i backed off at 750, continues to climb past 800-850 if you hold 120...
    NOW, logic and experience would say that my EGT's should be lower in 4th gear. In fact the first time I drove it with the EGT gauge it went past 800 and kept climbing (in 4th)!!! Performance is not even that good! 5th gives me lower EGT's for the speed I find... weird.
    So I'm not very happy, considering I've done 30kkm's with something that was sold to me as safe, and driving it so as not to labour it, and now knowing that the smoke screen it creates at 110 in 4th gear has probably ruined what was a perfectly healthy engine...
    I am having to drive it slower than I did when it ran a stock tune on 32's, just to keep it alive.
    For the record, photos were taken completely unladen, with two people in the car, the car also has a 3" mantec style custom snorkel on it. EGT probe is mounted in the EGR blank plate and completely covers exhaust port #1.
    Can anyone shed some light on this strange tune, or has anyone else had the same experience?
    Should I ask to return it for a refund?
    A bit concerned as right now I cannot really afford to spend the money on an NNN ecu and Td5 Inside tune.
    Thanks in advance for any input
    Jul 2014
    west of Transylvania
    IMO you should make a test with stock tyres before a final conclusion, with those huge tyres the whole addaptive strategy of the management might be mixed up as long as the new fuel map was not especially conceived for that by someone who really knows his stuff cos there's a missmatch now it the ECM's "brain" as with those tyres the VSS(vehicle speed signal, part of the addaptive strategy) is unexpectedly low according to the revs and torque delivered at a certain vehicle speed and the fuel map was ''calibrated"" for stock(or max 5% greater) tyres, as your's is manual there's no default value for VSS(only autos have it) so the management will compensate by overfueling.
    IMO for those tyres you need dedicated fuel map to not have any issues also if i understood well you dont even have a larger intercooler yet which is not healthy with any remap
    can't you take a live data log with a nanocom to see some MAF, MAP, IAT values?
    South Sydney
    Quote Originally Posted by sierrafery View Post
    I'm not sure if it quite works like that... the speedo is only 10% out compared to GPS, but as far as VSS and RPM are concerned nothing has changed... (gearing is still stock), the car just travels further for each revolution of the tyres, hence the wheel sensors do not read true road speed. Am I interpreting that right?
    The thing I can't work out is why it over fuels in 4th but not 5th...
    When I bought it they said it was fine to use with 265/75's, and did not recommend a change in IC unless i felt like it.
    I have since upgraded to a D2a intercooler (as mentioned before), which is about as good as they get anyway... no intercooler is going to take a further 200*C off my EGT's.
    I am curious what it would be like on standard tyres, unfortunately I no longer have any easily accessible.
    Thanks for the advice
    Jul 2014
    I made that deduction cos i've swapped the chip from my ECM(tachosoft remap) to a friend's same year D2 with 265/70/16 tyres(mines are stock 255/65/16) and we've got +100/150*C increased EGT on his, he has the original intercooler, i have a performance one...i dont understant that D2a intercooler thing cos afaik the auto intercooler is even smaller than the original manual one due to the oil cooler, unless your manual has a factory fitted cooler which is smaller than the auto, i dont know these things cos manuals dont have cooler around here
    i get max 700 uphill with the stage 1 chip and 800 with the stage 2 on mine
    about the VSS, the speed sensor's output is AC voltage which grows with the wheel's rotation speed but the manegement "expects" certain VSS inputs according to rpm and driver demand as it was calibrated from factory and when the initial equilibrium is mixed up any kind of things can happen
    Dec 2009
    Baldivis WA
    With the D2a reference, the 'a' doesn't mean auto. It means it's the face lifted Discovery 2. The intercooler fitted to the D2a are more efficient than the pre facelift Discovery D2.
    The intercooler is the same for a manual D2a & an auto D2a.
    Jul 2014
    Thanks for that "a" thing, i didnt know that, though, maybe down under all the manual D2s have a geabox oil cooler from factory but for not such warm regions they didnt export manuals with an oil cooler and the performance intercooler for the manual is bigger than the one for auto(300mm / 235mm high)... i should have said that i was referring to performance intercoolers not standard, my mistake cos i said "original" while i was thinking to performance, sorry
    about that pre-facelift and facelift intercoolers it means that all the standard intercoolers on the market should be the same now cos i can't find different part numbers for pre and facelift modells, only PCM100220 which they say fits all modells
    Dec 2009
    Baldivis WA
    Correct, all manual D2(a)s, in Oz at least, have a gearbox cooler. Which is why we need to make sure any performance intercooler for a manual is gearbox cooler comparable.
    Correct, pre-facelift intercoolers were part number ESR3777, this has now been superseded by the D2a part number PCM100220.
    Nov 2014
    Nirvana near Albany W.A.
    pre facelift intercooler 27 mm thick
    facelift d2a intercooler 40mm thick
    mr lr see what your egt reads after you wind up your boost but smokescreen in 4th ( not good )
    sierrafery if probe is in the same spot as your friends then its probably more to do with your intercooler especially if you are running higher boost, that his egt,s are higher than yours ,
    Sierraferys chips are still far too hot...
    Jul 2014
    Those figures were maximum readings uphill with 1500kg boat attached and when i was lazy to change back to 3'rd ... in normal conditions without towing it doesnt go above 550-600 uphill for short times, on motorway driving it's max 400 when i floor it to overtake something... IMO that's not bad at all, i've seen worst with a stage 3 map
