Results 1 to 10 of 22
Thread: 4x4 Australia article on CRD problems incl TD5!
    Avoca Beach
    Well the, what is the word morons? have a special feature on CRD problems in the latest issue.
    They include TD5s in the list of CRD engines.
    At least they didn't show the TD5 as having any common CRD problems.
    I wonder why?
    Could just be that TD5 is not a CRD engine. They say it has a Delphi system, when only the injectors are Delphi AFAIK.
    Regards Philip A
    Ferntree Gully, Vic
    Wait till they do a write up on independent suspension. The D2 is terrible in that department 4x4 Australia article on CRD problems incl TD5!4x4 Australia article on CRD problems incl TD5!4x4 Australia article on CRD problems incl TD5!
    Jan 2009
    Seymour, Victoria.
    CRD Td5?
    I thought it was a LUCAS developed fuel injection system.
    I've just had mine out and I could have sworn they were marked LUCAS.
    I've heard many people call it the first CRD. I think it's easy to to confuse a common fuel gallery as a CRD.
    So what if the article got it wrong. Those that know, know! Generally a very reliable engine. As with any older motor, have to keep on top of servicing.
    Best oil, best filters, best chance of a long life.
    Nov 2014
    Nirvana near Albany W.A.
    to any 4x4 action journos reading this .... when are you going to do a write up on td5's real bugbears you know .....snapped timing belts, problems with having to shim the valves ( all 20 of them), not to mention the balance shaft issue.
    Contact me here and I'll tell all
    Bairnsdale enjoying the rural view no rooftops to see here
    Quote Originally Posted by discorevy View Post
    to any 4x4 australia journos reading this .... when are you going to do a write up on td5's real bugbears you know .....snapped timing belts,
    last time I checked td5s don't have belts !!!!!
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    NSW SW Slopes
    Nor shims for 20 valves nor a balance shaft....
    Quote Originally Posted by Outback 1 View Post
    your right, it doesn't have belts, its only got the one.
    you have no idea how frustrating it is trying to install a balance shaft, its bearings then timing it in properly and that's assuming you can get your hands on one.
    I've still never managed to get the common rail-injector line union nuts to seat correctly.
    as far as engine goes its probably about on par with a 4bd1-t no wonder ford discontinued it.
    Nov 2014
    excellent I should've known you would have these bits in stock,along with humour bags .....apparently some vendors are nil stock atm
    99.87 MB
    to any 4x4 australia journos reading this .... when are you going to do a write up on td5's real bugbears you know .....snapped timing belts, problems with having to shim the valves ( all 20 of them), not to mention the balance shaft issue.
    Despite all of this, they don't use much petrol.
    Slunnie
    Nov 2012
    Acacia Ridge, QLD
    Question CRD
    Hi Guys, am I missing something? ( I like to keep abreast even though I drive a tdi, ) A Td-5 is common rail diesel or not? My understanding is "CRD" is a generic term for diesels that used a common very high pressure "rail" , and the fuel injectors connected to it are "fired" electronically. can you explain ?,
    Common fuel gallery ? cheers simmo
    PS I think the TD-5 is fine engine
    simmo
    95 300Tdi Defender wagon
