I used a hacksaw very carefully around the join, being careful not to hit the pcb inside. Don't need to cut it through the whole way round, just through one side then lever it open.
 Master
						Supporter
						Master
						SupporterI have bought a new casing / shell for my D3/4 (2.7) key, as old one is coming away at the edges. Anyone have instructions on how to dismantle them so I can put the insides into the new shell.
thanks
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
 Master
						Supporter
						Master
						SupporterIf you are handy with a soldering iron it is a good idea to replace the rechargeable battery. Mine lasted about 6-7 years. Cut the tags with sidecutters then use a solder sucker or braid to remove the tags and try not to burn the card
Take note of the key and spring locations and do a test reassembly before gluing carefully with super glue
 Master
						Supporter
						Master
						SupporterA multi tool might work better than a hacksaw. Can control it better.
D3 or D4
D3/4 doesn't help much as they are both very different keys.
 Master
						Supporter
						Master
						Supporter| Search AULRO.com ONLY! | Search All the Web! |
