 Originally Posted by
jimr1
				I had a miss on my dt5 at about 100 plus ks . I found It just by luck . I changed the injector harness , and while putting It back together noticed that the wiring harness that runs along the block under the head had worn through some of the wiring . Probably vibration , you would never see the problem because It's on the side facing the block , plus It had a good coat of oil as well . I was wiping the oil off the wires just to clean them up , when I found bare wires , they could touch the block and make a short . Cleaned them up , re taped them , put them in a sleeve , never had a miss again . I don't know if this is your problem , but worth checking out , before buying a new pump !!. Jim .
