Results 1 to 10 of 32
Thread: gear selection dial MY13 D4
    Nov 2014
    Beenleigh, Qld
    Hi All
    I have a MY 13 D4 started the truck up this morning gear dial came up and in a matter of seconds it went back down and then in about 20 to 30 seconds the gear selection dial came up and I was able to select reserve gear. and drove off.
    Could anyone let me know if this is a problem or is this normal with the D4 ?.
    It appears to happen when doing a cold start
    regards Kev..
    Williams West Aust
    Havent heard of this on a D4,it could be a transmission protection for the cold start.
    My CAT grader,and the previous one wont allow gear selection on a cold start,it just shows a dotted line for both forward and reverse gear to select.Only on VERY cold mornings,usually less than 1min,up to 2min max.Yes I do warm the machine before operating,just to get the heater working
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    LRD414's Avatar
    Oct 2014
    known fault
    Here you go Kev .... from Disco3 in the UK. Yours could be suffering from this.
    DISCO3.CO.UK - View topic - Rotary gear selector won't stay up when cold.
    A customer may report that the Transmission Control Switch (Rotary selector) intermittently fails to rise when the Start/ stop ignition button is pressed or may rise and fall immediately, particularly where ambient temperatures are less than 4 degrees C
    The motor within the Transmission Selector assembly may be at the lower end of the specification preventing it from rising within the required time span
    The fix is to replace Transmission Control Switch.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Williams West Aust
    Quote Originally Posted by LRD414 View Post
    Do they drop a little blue tablet in the tranny oil to fix it????
    Andrew
    Nov 2014
    Beenleigh, Qld
    Thanks Scott (LRD 414)
    The Disco has only 11,500 k up now. I think I will keep a record over the next couple of weeks and then contact the Brisbane or gold coast dealer
    and see what they have to say or do.
    Thanks for your reply Andrew I don't think the little blue pill with help
    with my D 4 problem
    Thanks again for your replies
    Kev
    Jan 2014
    Emu Park
    Quote Originally Posted by kmdisco View Post
    Hi All
    regards Kev..
    Interesting never heard of that before.
    Williams West Aust
    with my D 4 problem
    Kev
    I have identical ks on my MY14 D4,no issue yet.
    Andrew
    Download to fix, Adjusts the parameters of the cold Start issue.
    Brisbane,some of the time.
    So when you have the gear stick,one less thing to go wrong
    Bunbury, WA
    I would say that we don't have a gear stick, so one less thing to go wrong
