Results 1 to 2 of 2
Thread: Diary of TDI Conversion - Day 23 Hub breathers and speedo
    May 2002
    Sydney, Australia
    G'day Guys,
    I did not want to use the ABS system from the donor Disco so I removed the ABS sensors and had a plate made a plate to cover the sensor hole and also allow the install of a breather.
    The breather is then taped into the cover plate and breather lines extended into the engine bay.
    Here you can see the different speedo drivers - left one is the RR cable speedo driver and the right one is the Disco electronic speedo driver. As both in this case had 23 splines they were interchangeable and the cable speedo reconnected to the Disco transfer gearbox.
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    May 2003
    On The Road
    gotta love those brake lines [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
