Results 1 to 10 of 14
Thread: Snorkel or RAI
    Apr 2015
    Alaska
    Snorkel or RAI
    Does anyone know if there is a snorkel or RAI that does NOT require drilling to fit?
    I'm not sure about the one in this pic but I suspect it uses original vent holes only but not sure
    Sent from my GT-I9195T using AULRO mobile app
    Even if it uses the std grille holes, you still need to drill the windscreen frame for the upper support.
    '51 Series 1 80"
    '12 Defender 90
    Jun 2014
    Dubbo
    Quote Originally Posted by Larry View Post
    I've seen a write up somewhere, possibly on Defender2, where they have attached the bracket to the A pillar with sikaflex to avoid drilling it. Apparently its solid as a rock
    May 2012
    Boulder, CO
    Using one of the older metal mushroom top style, the side plate doesn't require drilling.... Well, one hole in the flange that's hidden by the plate. The windscreen can either be drilled, or a custom bracket made to mount to the flange that the door rubbers attach to.
    I wouldn't worry too much about the windscreen frame. They are easy to get ahold of, or you could silkaflex some grub screws in place, should you remove the snorkel/rai.
    Its amusing (and I was very much of the same mind set years ago) how people loath the thought of punching a hole in a vehicle...
    Reality is it really does very little to the value of the vehicle and often compromises your installations of items in the vehicle too.
    Now - I make a committed plan to the outcome of my modifications and then work out the best way to effectively achieve it. If holes are needed - then holes are made
    Emma (Mrs Tombie) shiny 90 is about to get a significant amount of work done and several holes will be going into it to achieve the outcome desired.
    Just keep it clean, make sure the install achieves your goal (dont drill holes then change your mind) and you'll end up with a fantastic result!
    Nov 2014
    wauchope
    Snorkle
    Here is a picture that requires only four small holes to be drilled in the windscreen frame.It also replaces the original intake tube. Comes stainless or powder coated in black.
    Kit is available from Momentum 4x4 in NSW.
    Apr 2015
    Alaska
    Looks pretty slick. Nice
    Oct 2014
    Fremantle
    Quote Originally Posted by grinna1965 View Post
    That's an awesome looking snorkel
    Jul 2013
    That looks great. I just emailed them to see if they're a reasonable price. Would look good in black on the perentie
    Feb 2013
    I was cringing about drilling holes too for the checker plates I made but once I drilled one there was no stopping.
