Results 1 to 9 of 9
Thread: internet connect problem
    Sussex Inlet. N.S.W.
    Just picked up a good used compac nx5000 laptop. I set up my wifi network and immediately it started downloading program updates. However I cannot connect to internet It is running xp. Any suggestions as to what is wrong. Obviously the wifi network is running but... Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Jul 2013
    Alice Springs, NT
    Sorry just to clarify - you laptop can download updates from the network but you can't connect to the net?
    If you laptop is getting updates it must be connected. Try going to run->cmd and type ping Google.com See if it successfully receives packets. If so it may be your browser may be trying to connect via a proxy and this can be disabled in the browsers settings (would only be the case if you haven't done a clean install and the previous person had these settings.) alternatively try to download an different browser
    Hi Synthium. Computer connects fine via LAN cable but not wi-fi. And yes, it is automatically downloading updates via wi-fi including XP service pack 3 plus another 48 updates last night. I just cannot get browsers to connect. I deleted firefox and installed a new version, all to no avail. I get the message that there is no wi-fi connection although there obviously is. I don't like being beaten by computers but.... Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Jul 2013
    Alice Springs, NT
    Sorry I am actually on holiday so not on the net much. You can try this
    Click "Start"
    Click "Run"
    Type "services.msc" in the field
    Find DHCP Client in the window that opens after you enter services.msc on in Run.
    Restart the dhcp client.
    Might work.
    Or you can try
    1. start then go to control panel.
    2. click internet options, then connections
    3. Click LAN settings then it will open automatic configurations.
    4. Remove all the check marks you see on automatic configurations and proxy server
    5. Press OK
    Or
    1. right click the connection either it is lan or wireless...
    2. choose properties
    3. then click one the internet protocol (TCP/IP)
    4. click properties
    5. check obtained both
    Or
    Solution > Firefox
    Go to tools > options> advanced > network. Click on setting and check no proxy
    IE7
    Tools> Internet options > Connections > Lan setting > Check proxy server.
    Try those 1 by 1 and see what works!
    I tried all these to no avail. The message I am getting is ...cannot find server at ( whatever search engine I try). Does this give you any clues? Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Jul 2013
    Alice Springs, NT
    Try going to run and type cmd
    Then in the console type ipconfig /renew
    Also it could be a firewall or Internet security/antivirus program thing. Try disabling them for now to see if that helps
    Or
    2 [right click] then click on [Property]
    3 click on [configuration] choose [Driver] tab
    4 then [uninstall]
    5 [turn off] or [Log off]
    6 [Log on] or [Turn on]
    7 your computer should auto-detect and install your wireless hardware
    if not it will ask for driver
    8 if so just follow the add new hardware procedure
    After that I am not sure. It could be a setting in your router regarding the DNS or even the type of encryption on your router - you could try changing between wpa and wep
    I have a wi-fi dongle for travelling. I set that up and it works fine, just not on my wi-fi modem. This is relatively new and is Netgear 11. Works fine around the house, just not on this laptop. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    May 2006
    Ulverstone,TAS
    What about backing up the system files on dvd then do a complete reboot .
    Sent from my SM-G900I using AULRO mobile app
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    I would love to do a clean install but it doesn't seem to have a copy on hard drive.I have a W7 disc. Maybe I should just install this. There is no data to worry about. On second thoughts the system is working now. Don't ask me how. It wasn't last night. COMPUTERS!!! Jim
    Jim VK2MAD
    '17 Isuzu D-Max
