Thread: Deck height
    May 2003
    On The Road
    Deck height
    The measurement from the crank centre to the deck of the block,,
    anyone know what it is for a Thor 4.6 V8?
    and/or the 4L?
    G`day ,
    no , i don`t the best the i can give you is the piston top to deck is 0.020". Should add this is 4.0 , 8.23 - 1 stamp
    Rod length , center to center( crank to pin )
    Pin height , pin center to piston top
    deck height , piston top to deck
    TTDC
    May 2003
    On The Road
    Thanks Peter,,
    I am trying to organise Stack heights and block heights between the 4 and 4.6.
    The pistons crown CC's are different and the rod lengths are also different. I'm not sure about pin height yet,,
    box 2 gives some info about rod length,,
    Buick 215 Rover 3.5 Land Rover 4.0 and 4.6 differences
    G`day ,
    i did leave out ( not on purpose ) that you will also also need to add the figure for half the stroke to the total .
    I think you`ll find the quench height will give the most difference . This takes into account everything above the top of the top ring to the chamber top .
    Had a look at the link , close but not same as factory manual figs more middle ground . Factory also give both met imp .
    G`day Pedro ,
    thinking about this today .
    The only figure using found could be an approximate one , unless it was actually measured and then it would only be accurate for that measured .
    For both 4.0 and 4.6 the figs for half the stroke , rod length c to c , half dia of gudgeon would be easy enough to find ( haven`t done but think it will give the same outcome for both ) .
    A measurement from the top of the gudgeon to the piston top would be pretty easy if one had a piston .
    The 020 i mention is measured .
    I notice Bundalene has a set of 4.0 pistons he is selling on Ebay .
    Also Garry Cole ( gone but not forgotten ) has some 4.6 pistons .
    Maybe they could help you with the fig for the pin top to piston top needed if you are able to contact them .
    To my knowledge the piston concave is the ratio change other than that the pistons are same .
    Same rings for either/any 4.0/4.6 piston
