Just as some side info for whoever is interested..
A brand new crate engine from J Land Rover can be purchased for round that 9K - 12K, in either a brand new or a factory refurb option, I've used both (depending on available supply), the factory refurb, the only used part on it would be the cast iron block and I suspect it prolly gets built on the same engine assembly line as any other engine. All I do is supply the year model, VIN. Supplied as what is called "stripped" but includes:
*Complete bottom end, including upgraded crankshaft & oil pump assembly (for the 2.7lt).
*Cylinder heads fitted complete right upto glowplugs, fuel cooler, the plastic cam covers.
*front timing assembly complete with cover.
*Oil filter & engine is filled with oil.
Yes there is more labour cost to strip all the ancillary parts off the old engine, clean inspect, fit to the new engine. But EVERY single engine change I've done has been absolutely trouble free, I'm almost into double figures now with engine changes. I wont even consider used engines from wreckers that will say ANYTHING for a sale "low mileage" "its in great condition" "oh its not from XX year model, but it will work".
pic is one such smooth change over;
https://www.facebook.com/aztech4x4/p...type=3&theater
For owners its peace of mind you are getting a perfect new engine, for repairers you know its going to work in that year model and be trouble free.
Daz
