Results 1 to 9 of 9
Thread: Trailer lights
    Gold Coast, Qld
    Trailer lights
    Which colour wire would activate the breaklights on my trailer?? I had to rewire them at the weekend and when checking them only the driving lights and indicators would work and not the brake lights, even though it is a double filament bulb.
    All the wires from the trailer are connected so i'm at a loss.
    Hope someone can help.
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Barwite. Victoria
    If the trailer is wired correctly the RED wire is for the brake lights
    Try this for a 7 pin
    http://peterpam.customer.netspace.net.au/7pin.jpg
    or this for a 5 pin
    http://peterpam.customer.netspace.net.au/5pin.jpg
    This should solve your trailer problems
    Apr 2002
    Bellara 4507
    32.43 MB
    on normal 7 core trailer wire it is usually
    yellow, left flasher
    black, reverse or auxillary power
    white, earth
    green, right flasher
    blue, electric brakes/service brakes
    red, brake lights
    brown, park/tail lights (On a round 7 pin, its the centre pin)
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Gold Coast, Qld
    Thanks guys
    That's exactly the info I need to work through the problem so will have another look later and see if I can work it out.
    Appreciate the input
    rangie5litre Guest
    On this subject, I'm resurrecting a '73 Viscount caravan. How does one go
    about getting a 12 volt supply to the 'van for the 12 volt interior lights
    Doesn't appear to enough pins in the plug spare, or do I use the pin marked
    ÁUX'? I thought that was for electric brakes....................
    It's wired as above with a flat 7 pin plug, and I fitted new combination & number plate lights today, rego is due in two weeks.
    Cheers Scott. 8)
    Barwite. Victoria
    You can use it for elec-brakes or direct power to the van,
    you only need to wire it up to suit
    I personally would leave it for the elec brakes and run
    an independent wire of 4-6mm fused directly off the spare battery
    with an "Anderson plug" at the rear of the vehicle
    rangie5litre Guest
    Thanks 84RR, I'll check it out. My van has overrun brakes. I can't see where in or on the van to wire the 12 volts to, there's only a 240v inlet on the drivers'side and a 240v outlet on the passenger side where the annexe goes. Do you think I should talk to an auto sparky? 8O
    Cheers Scott.
    Barwite. Victoria
    If you have a 3way fridge fitted
    check where the wires come into the van,
    that should tell you if it has been wired up for power ex-vehicle
    It could also have a battery tray fitted under one of the seats
    rangie5litre Guest
    Thanks 84RR,
    Fridge says gas or 240V..........maybe the 12 volt lighting isn't wired up? I had a look today and there are 12V globes in the fittings as well as the 240V ones.
    I'll have a look for a battery box or similar and see how it works out.
    Cheers Scott 8)
