I read this in the manual however when I tried it, it did not work.. thought it may have not been available on the pov pack...
I recently went to Gordon's seminar, and remember him saying you could make the stationary vehicle change height by holding some button/s on the remote, and opening and closing the rear passenger door as the controller. Anyone with details please?
2003 D2a Auto TD5 good Landy gone
2015 D4 probably the most amazing yet, why get a RR?
Don' know if a D4 is the same but on a D3,
The key must be set up for height control.
Hazard lights on.
Doors closed.
Hold down LR button.
At the same time press lock or un-lock button, car goes up or down.
Very handy for taking on/off a heavy trailer but be sure the tow ball is free or you will bend your jockey wheel.
Jonesfam
I think you've confused two separate examples. Yes, you can use the key fob to lower/raise the car as long as the hazard lights are on (D4) as per Jonesfam's post. Earlier D3's could have this functionality over-ridden, so may not be available.
The "open door" trick was to level the car for attaching a Treg Hitch trailer.
Gordon
Aaron,didnt they show you when they delivered it
Its OK,they showed me,I couldnt get it to work.
DER,hazzard lights on,I remember now.
I blame all my blood rushing to the member for LandyAndy at the time.Well it was my first new car
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
I think Andy meant "DER" as in
"I was a bit thick."
For those whom this works, complete instructions please.
Even better is to use a Blue Tooth IIDTool and raise or lower the car using a phone or tablet. No need to have the hazard lights on for that to work.![]()
