Results 1 to 6 of 6
Thread: Removing rear interior trim
    Does anyone have any hints on removing the rear side interior plastic trim, including the cubby boxes?
    There looks to be a fair bit of unutilised space behind this and am looking for places to mount arb compressor and a few other bits and pieces.
    (I have triple battery traxide kit so engine bay is out as far as compressor install goes.)
    Dec 2011
    Forrestfield WA
    If I remember correctly you start by removing the tie downs and the cover plate for the seat folding mechanism. Then it is just clips. The side panel includes the bit of carpeted floor panel up to the seats, from memory. I haven't done it for a few years. Someone else may be more helpful but this might give you a start.
    Bob
    Jan 2015
    Interior Trim and Ornamentation - Rear Quarter Trim Panel
    Removal andInstallation
    Removal
    1. Fold down therear seat backrest.
    2. Release thedoor aperture weatherstrip.
    3. Release thesafety belt anchor.
    Remove anddiscard the bolt.
    4. Release the tailgateaperture seal.
    5.Remove the support spigot from the tailgate.
    Releasethe clip.
    6.Remove the rear quarter trim panel.
    Removethe Torx screw.
    Liftthe storage box lid and using a firm grip,release the window clips by pulling the trim inboard.
    Releasethe remaining 6 plastic clips using a suitable tool.
    Disconnect the 2 electrical connectors.
    7. NOTE: Do not disassemble further if the component is removed for access only.
    Remove thestowage tray.
    Release thecover.
    8. Remove the audio control switch.
    Release the 2 clips.
    9. Remove the accessory socket.
    Last edited by l00kin4; 19th October 2015 at 04:52 PM. Reason: add 1 image, tidy up text
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Thanks for that.
    Interesting it mentions to discard the bolt from the safety belt anchor. Wonder how much it is going to cost me every time i want to remove this panel? Are they special bolts used?
    Dec 2011
    Forrestfield WA
    What I said was what you do to remove the floor panel to get at the third row seat fixings. Sorry, the old brain is not as good as it once was!
    Bob
    Jul 2017
    Tail Gate Cable Wind Mechanism
    First Post
    Hi Peoples,
    So firstly - no need to remove seat belt retaining bolt.
    Secondly will this get me access to the Tail Gate Cable winding mechanism. There appears to be an issue with mine retracting properly.
    This would also allow to check the cable to the rear power point.
