Results 1 to 10 of 18
Thread: 2002 td6
    Feb 2009
    Bondi
    2002 td6
    I have a problem with my rangie going up hills
    It has no power and I am pushing to get up to 40 km on a steep hill
    Recently I changed the air and oil filters. The problem was there before I did the service.
    Can anyone shed any light on this problem
    Cheers Paul
    Hunter Valley
    Maf sensor. Disconnect it and go for a drive
    Sent from my GT-I9295 using AULRO mobile app
    It doesn't leak oil, Its sweating power
    Feb 2009
    Bondi
    L322 2002
    Not sure what a maf sensor is, where would I find it to disconnect .
    Cheers Paul.
    Aug 2010
    Sunbury, VIC
    Does it whistle at all under load? If so, check the small vacuum line between the inlet manifold and the turbo actuator plenum on the drivers side of the engine. Pull the hose off and stick your finger over it - if you have no suction, you will have no power as the vacuum is required to operate the VNT turbo. If you have vacuum there, check at the turbo for the same thing. The vacuum line gets brittle and cracks and this causes a slow decline in power until it won't go up hills anymore. It will still start fine and not throw any fault codes.
    Hunter Valley
    A MAF is a mass air flow sensor. it measures the volume of air going into the engine. when you disconnect it will go to default setting. It still wont have full power but will be driveable if the MAF has failed. It is a common failure. It's located near the air filter.
    https://www.google.com/search?q=m57+...tSkb0xyNZ40%3D
    Nov 2005
    Maudsland, QLD
    I had similar issue and it turned out to be injector harness. $130 for a new harness and about 40 mins later and issue was fixed. I hope yours is as simple!
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    Feb 2014
    With power loss, I always recommend checking the inline fuel pump, put ur head down infront of the L.H rear wheel (not while moving or in neutral) and if you can hear a whinning/buzzing sound, it most likely needs to be replaced along with the fuel filter.
    it will come to the point where they can stop completely and be intermittently working.
    I ended up replacing it twice, second time with a more common/cheaper/reliable bosche pump
    Aug 2010
    Sunbury, VIC
    There you go Brummy - that should keep you out of trouble for a while checking that lot - all can cause your symptoms and all of them are pretty common.
    let us know who wins the jackpot or if we were all wrong.
    May 2003
    On The Road
    some pics of the different engine bay parts/locations may help
    Feb 2014
    Quote Originally Posted by bacicat View Post
    We should start up a competition....
