mod the bracket while you are at it.....FWIW pretty sure early defender were the same set up.
Hi All,
I need to do some work on the front swivels on my 2004 Defender TD5 Xtreme, which is fitted with ABS & Traction Control.
Due to the design of the later brake hose brackets, I will have to undo the brake lines to remove the caliper assembly.
Are there any complications with brake bleeding caused by the ABS? I will try & plug everything to reduce fluid loss while I'm doing the job, but I was wondering about any issues resulting from the presence of the ABS system.
Any information would be greatly appreciated.
Lionel
I had to disrupt the brake lines a while ago myself, and came across the stupid bracket design. I plugged the lines when I disconnected them, then modified the bracket (just needs a slot cut in it to the hole, if I remember correctly?). I was expecting to have issue bleeding when I reconnected, but I didn't seem to get any air in from the reconnection process (or not enough to make a difference, and it travelled up by itself).
so long as you have not permitted air to get in above the ABS module or allowed the fluid to drain from the abs module then you can bleed the caliper as per a standard brake system providing you do not allow air to enter the abs module while bleeding.
Yes, the bracket's a pretty stupid design. Even if one slots the hole so that the caliper can be hung up, the metal brake pipe is rather more vulnerable than it is with the old design.
I'm not too concerned about it this time though, as I want to run some new fluid through the system.
Lionel
This is not really my main concern, but point taken.
They have changed the run of the tubing with the later models, which makes it a bit more awkward to safely hang up the caliper, even with the bracket slotted, than it used to be.
The metal tube is a bit more vulnerable to damage.
Lionel
 Master
						Master
						Its not that bad a job easiest thing to do is put line lockers on the rubber brake lines before anything is undone then it just a simple job of bleeding the calipers as you would with any brake system.
I had to do the whole bleeding process about two weeks ago after putting new brake lines on and was fairly easy job with a nanocom... just bleed the modulator via nanocom then did a normal pedal bleed with ignition off. You can power bleed with the nanocom but takes a little longer as only moves a small amount of fluid each time.
