Results 1 to 4 of 4
Thread: A Couple of Steps Forward...
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    My Ancient Mariner inspired starter motor (Start - "th one in three" key strokes) decided to just whir. It no longer bothers to engage the throw-out bearing. So the engine is not being turned over. Just a nice little whirr.
    I put in the new cylindrical fuel pump, hooked up all new fuel lines. Bent the lines and put double flared joints on them. I installed brand new auto electrical wire and I even put a switch on the circuit. I can now have the ignition on and choose whether or not to have the fuel pump chugging away.
    I put in the new electronic distributor. Of course this meant that I had to fabricate a new accelerator cable mounting bracket because the old one was too close to the engine. This caused the new, wider distributor not to fit between the engine and the old accelerator bracket.
    I even have a brand new timing light to get the timing right.
    I just cannot get the vehicle started because the starter motor decided it can only be intermittent for so long. Well it has been giving me notice for quite some time that things were not well with it - so it has turned up its toes. Its metabolic processes have ceased to function - it is a dead parrot starter motor.
    Accessed 25th of October 2015 from, [ame]https://www.youtube.com/watch?v=Oj8RIEQH7zA[/ame]
    Maybe the starter motor is just "resting" because I have done so much work on the Land Rover lately?
    Kind Regards
    Lionel
    May 2015
    Southern Adelaide
    Nah, you're obviously close to getting everything sorted so it's having to come up with new problems
    Irymple, Victoria, Australia
    Sounds like it is not throwing out.
    Break it down and give it a good clean and lubricate the moving parts.
    If it's a Bosch they are hardy and reliable.
    If it's a Lucas well.......!
    I priced an aftermarket reduction starter (to suit a Holden straight six) the other day, $185 and I am told they are rather good quality.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Oct 2015
    Tasmania
    I would just get out the crank handle myself but .... its a Holden.
