Results 1 to 8 of 8
Thread: driveline vibration / chatter
    Apr 2002
    Bellara 4507
    32.43 MB
    My rangie seems to have developed a fair bit of driveline chatter
    esp in the 60-80 kph range
    doesn't seem noticeable above 100kph
    makes the whole cab vibrate
    i can't pick it ...
    checked and greased the uni's, had wheels rotated and blanced, replaced panard rod bushes
    does a torque converter playing up give you those sort of symptoms?
    got me beat....
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Feb 2005
    Radius arm bushes??
    May 2008
    Horsley Park, Sydney
    We had a similar problem with our Defender vibration between 80 - 90 especially on a downhill corner. Turned out to be panhard rod bushes, even though there was no apparent movement while watching it, while someone else turned the steering wheel.
    Erich
    Apr 2012
    Orange, NSW
    Auto gearbox mounts
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Handbrake part on.
    DL
    NSW SW Slopes
    How worn are the splines on the front tail-shaft's sliding joint - is there up and down movement?
    Apr 2002
    Bellara 4507
    32.43 MB
    will check that lot out next day or so, thanks
    Moruya Heads/Sth. Coast, NSW
    You really need to have the wheels off the ground to unload any tension on the uni-joints to test for wear, esp. the front one's, take a good pry bar/long screwdriver and torch and give the uni-joints a good workout, Regards frank.
