Originally Posted by
Ranga
What a cute little welder!
It would struggle with 3.2mm rods.
You've got buckley's finding a decent range of rods in 2.0mm in a reputable brand.
Inverter machines are much more efficient than the transformer based machines.
As for the circuit breaker, it's got more to do with the conductor size in your walls- as this is what is being protected by the circuit breaker. If you haven't already, seek advice from an electrician, then buy a 15A machine which will do everything you want, and you'll have room to move to a larger machine if / when the time comes.
-Mitch
'El Burro' 2012 Defender 90.
