Results 1 to 10 of 12
Thread: My Pin Won't Fit in the Hole !
    Dec 2015
    ireland
    Hi , Maybe someone on here could help with this . I'm doing my first ever timing belt change , I have everything lined up , crank locking pin in place , but I cannot get the injection pump timing pin to go in . I can see the hole apparently lined up when I shine a light into it , but the pin will not go through . I tried loosening the three bolts and wiggling the pump with a socket on the center bolt , but it made no difference . Any clues ?
    Dec 2013
    First of all, your post is titled soooo wrong
    I take it it's a 300tdi.
    What's the diameter of the pin?
    Hopefully you didnt undo the bolts that mount the gear to the pump, thats how you do the fine adjustment of the pump.....
    you dont need to use the timing pins they do make it easier however.
    check that the hole isnt obsucred or damaged
    check that the pin youre using isnt bent and is the right size
    make sure that the timings not out a tooth on the belt and has then been compensated by backing the pump.
    http://www.aulro.com/afvb/projects-t...=tdi300+timing
    thats the thread I did up on doing the timing belt, its got the sizes of the pins in some pics as well as the method for without timing tools.
    you could also try out leaving the crank locking pin out, walking the crank back and forth till your timing pin fits in the pump and then resetting the crank position and installing the locking pin. Its possible that the tensioner has slipped a bit or the belt is excessively stretchy so the timing is out just enough to be baulking the pin. You can also achieve this by gently rocking the pump by means of the center bolt. If you see the belt "flexing" then the belt is stretched or the tensioner has slacked off.
    either way, if you have slacked the gear mounting bolts for the pump you will most likely want to check the injection pin height when you're finished doing the timing belt.
    Best of luck.
    Dec 2015
    ireland
    Hi , Thanks for reply , I've checked and the pin is 9.5 mm , it's not bent , and the hole looks clear . That's what puzzles me . I can see the hole in there but the pin doesn't want to know . Before I stripped it out the engine started instantly with good power and no smoke . When I took the timing case cover off , I was amazed to see that the old type tensioner had split it's outer rim . Part of it was lying at the bottom of the case but luckily the other half remained in contact with the belt . Not much tension but when I wound the engine round clockwise all the marks lined up just where they should . With the crank pin in and the cam gear on it's mark I removed the old belt , going by the " Trailerfitter's video on Youtube I should then have been able to loosen the three bolts on the front of the injection pump pulley and wiggle it about so the pin would fit . So I tried that but still would not go in . Pushed a bit harder and TWANG ! the buckin' thing jumped over to the 9 o'clock position ... pulled it back this way and that but still that pin will not go in ,,, so that's where I'm at . Any other ideas as to what's happening here ?
    Moruya Heads/Sth. Coast, NSW
    What are you using for a "pin"?
    If it is a drill bit I assuming you have made sure the part to be inserted is free of burrs and bends.
    I used a 3/8" drill bit shank with no problems, only reason was I didn't have a good 10mm one.
    Is it an Auto or Manual?
    Might sound silly but check the keyway in the crank snout is at 12 o'clock, good luck, Regards Frank.
    Just like to confirm that the hole in the outer plate has a "U" shaped cut-out and is at the 11 o'clock position, Regards Frank.
    Dec 2015
    ireland
    Frank , timing pin is a 9.5 timing pin , manual , everything is aligned , crank at 12 , nothing bent or burred , just won't go in .
    Aug 2012
    Logan,Queensland
    With the belt removed, completely remove the 3 bolts that hold the injector pump pulley and then remove the pulley itself.
    This will give you access to the drive sprocket so you can see what is going on.
    When you reinstall the belt make sure that the injector pump pulley is turned clockwise before offering up the belt.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Dec 2015
    ireland
    Good idea jboot , I'll try that tomorrow .
    Dec 2015
    ireland
    So now I know why my pin won't fit in the hole . Took the pulley off to get a better look but there's no damage or obstruction .The hole is just too small . I measured the pin and it's exactly 9.5 mm so the hole must be just a shade less . Nevertheless I was able to insert the pin part of the way and then using Land Rover special tool BFH tapped it gently in a little more till it sat nice and square with no play at the gear . I'll have to use a vice grips to remove it when the belt is done but I have the pump where it's supposed to be and that's all I want .
