Results 1 to 10 of 20
Thread: electricity meter has wrong time
    Sep 2012
    Adelaide Hills
    hi guys.
    i have an old school electricity meter with a mechanical timer for peak and off peak times.
    ive had a look at it today and noticed the time is about 4hours out as you can see in the photo. photo taken at 4.15pm
    does it need to be fixed?
    who fixes this?
    can i fix it myself? i cant see any buttons or screws to turn.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Yinnar South, Vic
    You would have to snip the tags and crank the clock around...wouldn't bother, just means your off peak is on at a different time, which I'm assuming is hot water?
    Jul 2009
    Hobart
    Hi,
    If the time error suits your habits and saves you money, do nothing.
    If it doesn't, and it is costing you money, complain.
    Apr 2011
    Whyalla S.A.
    report to SA Power Networks faults and emergencies, note your meter number, the equipment belongs to them, if it stops you either have no hot water or 24hr a day hot water $$$.
    yes I am an electrician here in SA
    It wont cost you to sort it out
    Yinnar South, Vic
    Quote Originally Posted by mark_coffey View Post
    Does your time clock not simply switch a contact which then the off peak meter ticks over for the period of time the off peak time clock contact is made, so has no effect on $$$
    Apr 2011
    Whyalla S.A.
    these timers have a mechanical back up to an electric motor to drive them, they have a tendency to slow down and then stop, you can get the mech rewound up like a clock but its generally about time for quits for the timer. the replacement electronic meters have the J tarrif inbuilt with an external boost button, much more reliable.
    most people get a bit miffed when their power bill increases about 500% due to the hot water heating up every time you turn a tap on.
    May 2014
    Tamworth NSW
    Quote Originally Posted by rovercare View Post
    I'd be careful about snipping the tags, I thought this would land a fine or similar for tampering with the device?
    -Mitch
    'El Burro' 2012 Defender 90.
    Sep 2012
    Adelaide Hills
    well i learnt something today, i didnt know that off peak only applied to the hot water service. i had been doing the laundry at night thinking i was saving money. ha.
    a guy at cfs is a former electrician, he said to leave it as it working in my favor.
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    mikehzz Guest
    It sounds to me like you are still on the old slow electricity. It might be worthwhile checking if high speed electricity is available in your area? Let me know how you get on with that.
    Williams West Aust
    Does it have a spinning disc???
    If you want cheap power,drill a tiny hole in the case and insert a toothpic to drag on the wheel,it takes little friction to stop it = free power,its how the hydroponic houses get away with not getting noticed.You just need to know roughly when the meter gets read as they look for toothpics
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
