Results 1 to 10 of 21
Thread: Salisbury later one in yes or no
    Dec 2010
    cairns
    howdy all well since my epic fail which resulted in me stuffing up my pinion bearing, I am considering replacing the salsbury diff with the latter type, has anybody done this and what are my replacement options?
    got a bit of metal out of the diff just don't want to have to go through this again, if its going to be replaced may as well do the lot any advice appreciated cheers all.
    St Helena,Melbourne
    1.13 MB
    Stick with the salibury diff , anything else is a cheese stick.
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Dec 2010
    cairns
    banjo diff
    would not the banjo diff as used in the perentie be stronger?
    Safety Bay
    Rover with all Ashcroft internals. Pat
    Bearman's Avatar
    Hay Point
    Quote Originally Posted by mudder110 View Post
    Eh? where did you get that idea from. All perenties have salisburys in the rear.
    Cheers......Brian
    1985 110 V8 County
    Dec 2010
    cairns
    rover diff
    Quote Originally Posted by PAT303 View Post
    maybe a Detroit and hi tough axles in it pat, just like the idea of being able to pull out a diff and have it repaired if need be. cheers
    South Sydney
    I would leave the Salisbury in it, pay a diff specialist to set it up once and never worry about it again.
    NSW far north coast
    Quote Originally Posted by MR LR View Post
    Ditto.
    Once set up the go forever.
    The only problems I'm aware of were the ones grossly overloaded that pulled axle tubes in extreme conditions.
    Nov 2008
    Illawarra
    If you're rebuilding it there are a few options, stock, Detroit and hytuff, or do what a bloke on here has done and refitted it with Dana 60 internals. I think it was county v8, have a look at his build thread with a 5.7 injected v8. He also did the same to his 130dc which had a factory rover rear. He removed the rover and put in a d60/ Salisbury.cal415 is his name.
    Numerous threads.
    http://www.aulro.com/afvb/modified-z...version-6.html
    Dec 2010
    cairns
    salsbury
    Quote Originally Posted by frantic View Post
    Numerous threads.
    already have maxidrive axles and flanges think Detroit and and full rebuild, no drama pulling the pinion bearing can I just replace it and shim it'then drive it to maybe Townsville? no one here that could do a full rebuild need as much info and advice as I can get, everyone here has been so helpful
    cheers all.
