Thread: Perentie gearbox
    oowa Guest
    Perentie gearbox
    My gearbox, when what appears to be warmed up ,won't engage second gear, going up or down, double clutching or anything, it is like the gate isn't there.
    Any thoughts, clutch seems fine, no noises, just a 3 speed right now
    BRUCE
    Hay Point
    Quote Originally Posted by oowa View Post
    BRUCE
    Could be a few things Bruce, mainshaft endfloat, rear snap ring problem, synchro ring, worn thrust bearings, selector shafts or pads etc. Sounds like it's time for a rebuild. Does it shift normally when cold?
    Cheers......Brian
    1985 110 V8 County
    oowa Guest
    Gearbox
    Yeah I can get it in 2nd, but not for long, 1st feels a bit tight, 3rd and 4th not a problem.
    I'd love to drop an auto into it, but I hear that's a bit tricky matching the transfer case up to it.
    I also hear a 5 speed Td5 is a good choice to consider as well.
    Bruce
    Kingston, Tassie, OZ.
    Bruce i would leave it lt95. The auto trans conversion done properly is a very expensive affair. And the 5 spd from a td5 is a toy transmission. If you rebuild the lt95 correctly and turbo the perentie it will be the best use of your $$$. And originality (bar the turbo of course) will be retained.
    Jc
    oowa Guest
    Gearbox
    Thanks for replies,
    I'm in Sydney, can anyone point me in the direction of a reputable workshop for carrying out this work.
    KLR in Penrith are Perentie specialists☺
    Jc
    Bush Animal Guest
    oowa why don't you bite the bullet buy a manual and have a crack at rebuilding the box yourself.Cheers the Bushanimal
    Bush Animal Guest
    Justinc I read about what you said that there is a company that fits an auto to the 3.9 engine I am a paraplegic and am only allowed to drive an auto .I am getting a bit sick of getting someone else to drive me around in my perentie and them having all the fun.It would be great if you could give me some info on how to contact these guys to have a chat to them cheers Noel
    Quote Originally Posted by Bush Animal View Post
    Hi noel i agree 100% mate of course you should be driving it!!☺ do you want to call me on 0408995635 tomorrow early about 0730 and ill have a chat with you?
    Jc
    Brisbane, Queensland
    A few have been down this dry gully.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
