Results 1 to 10 of 16
Thread: 130 Rebuild project
    Wanderlust Guest
    130 Rebuild project
    Gday everyone, after lurking in the background I thought it time I joined in and registered.
    Ive started a project breathing new life into an old 96 130 defender I picked up from a friend the plan is to strip it down repair whats needed and rebuild again with a new tray and slide on camper.
    Ive stripped it down to assess what needs to be done including motor gearbox/transfer-case, not too many surprises found but I do have some questions that I'm hoping members can answer.
    I hear a lot mentioned about upgraded cylinder head on later models can someone tell me when they came in and if my 96 mod TDI is likely to have one.
    The land rover engine manual includes a caution saying not to de-glaze the cylinder bores does anyone know why as normally I would have them honed before fitting new rings.
    Ive also found two small internal cracks on the exhaust manifold where the turbo vain faces is this common and does it present a problem as the turbo itself is fine.
    Thanks in advance for your help.
    Nov 2015
    Tamworth
    good to see another 130 project on here, im currently rebuilding a '98 130. Post some pics, lets have a look
    Oct 2007
    Wantabadgery, N.S.W.
    Welcome Wanderlust, 130's are such good tourers. I'm sure someone will be along shortly to answer your technical questions.
    Don.
    Free Again Thanks Dan
    Firstly welcome
    When it is mentioned upgraded head it is referred to mainly the AMC Head which has different water gallerys
    Some say it is needed i guess if you feel you need it and have some spare coin Break a leg.
    There is a fellow not to far from you that is a vendor on here and also has a Ebay store (Roverlords) if you needs parts .
    Im just down Narre not far away
    99.87 MB
    Good stuff Wonderlust, I'd love to build up a 130 like that. What type of cab are you doing?
    Slunnie
    Wanderlust Guest
    Thanks for the welcome and the replies everyone as soon as I work out how to post pictures Ill include a few of the progress to date.
    rangiman, thanks for the info on the head I have an option on a rebuild kit that contains a new head with the improved cooling Ill probably go with that as well as an improved radiator to be on the safe side.
    To answer Slunnie's question its a crew cab with a drop side tray which will suit my plans for a slide on camper setup.
    Once again thanks for your replies pic,s to follow.
    Geelong, VIC
    Great project. Looking forward to the build progress.
    As well as a good cooling system, plan for some form of engine temp alarm like an engine watchdog etc.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Wanderlust Guest
    Gday everyone, as promised here's a couple of pics of the car as it arrived and being dismantled.
    Attachment 104006
    Attachment 104007
    Attachment 104008
    Ive almost completed the list of parts Ill need ouch it adds up very quickly doesn't it, never the less it will be worth it to know its been done properly.
    Nov 2015
    Tamworth
    looks like your images aren't showing.
    Here is how to do it:
    when you create a post, before you reply, scroll down and you will see Additional options - attach files - [manage attachments] - then, [choose file], [ upload] - grab the image from your computer and upload it this way.
    There may be other ways to do images here, but thats what I do.
    Wanderlust Guest
    Thanks Andy 130
    OK lets try it again hopefully here is the pics.
