The smaller from is from an early Range Rover I'd say.
I have two LT95,s here with two different linkages.
One is a cable exiting from the bottom LHS of the backing plate and the other is from the RHS hooked up to a linkage bolted to the box.
What were the different applications?
My old 110 has the small drum brake and I was thinking of swapping one over.
Keith
L322 tdv8 poverty pack - wow
Track Trailer ARN 200-117
REMLR # 137
AFAIK the Rangie was a smaller dia but longer handbrake drum with mechanical leverage off the transfer box & the 110's were cable linkage. You need to be aware that prop shaft lengths will differ between them & also I believe the 110 unit is more capable.
Are talking of swapping the whole box or just the handbrake assy, as the ratio's will be different. I have a chart somewhere that shows the LT95 ratio's & serial no's.
REMLR # 137
You may be right about how common it is.
Here is more info I found after a quick google:
Reference1982 - Range Rover in Australia
Highlights:
Introduction of 4-door Range Rover in April 1982, also as CKD assembly for the Australian market.
High compression engine with 10% less fuel consumption introduced
Note that the Australian door mounted rear view mirrors are positioned longer backward than on the similar UK built Range Rover's.
Engine V8 Petrol 11D with Carburettor Zenith-Stromberg 175CD type:
- 3.5 ltr V8 High Compression: 9.35:1
3528 cc V8, Max power: 125 bhp (93.2 kW) at 4000 rpm. Max torque: 190 lb ft (258 Nm) at 2500 rpm
Manual Transmission 12C with integrated transfer case LT95
- 4 speed and transfer box, - central differential lockable
high (1.0000 - 12C00001A to 01060A) - From Feb 1981
high (0.9962 - 12C01061A -on) - From Sep 1981
and low (3.32) ratio.
Gear ratios:
1st. 4.069; 2nd. 2.448; 3rd. 1.505; 4th. 1.0; R. 3.664
Pretty sure the rear output housing is different for the smaller drum, and propshaft is same length.
Steve
1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
1988 120 with rust and potential
1999 300tdi 130 single cab - "stock as bro"
2003 D2a Td5 - the boss's daily drive
smaller drum is rangie larger is county/perentie (roughly there is some cross population especially now that theyve been had at by people who want the other than what they were fitted with)
its a bolt over conversion but you need the output housing and linkage assmblies. If you have the 2 boxes side by side its obvious and easy, if you're looking at a parts book its less obvious what you need.
from memory the ratio change from the advertised 1.00 to .996 came about from a change in the gear design and the primary gears dont interchange but I've never personally been caught out with an odd bod box, ordering parts by the case id numbers has always worked for me.
Sorry, I did not make myself clear.
Yes the small drum on the 110 is the same as a Rangie one.
The other two are both Perentie large drum but there are two different mechanisms. One a cable from the bottom left and the other mechanical from the right. I can grab some photos tomorrow if needed.
Just wondering what the different applications were.
Which would be the easiest to swap over to the 110.
Keith
Keith likely the linkage type one maybe from a stage 1??
Jc
