Results 1 to 10 of 36
Thread: Thicker rear diff crown wheel on T/C puma?
    Nov 2014
    Sydney NSW
    Hi guys,
    So on the 20th of January my truck is booked in to get a Detroit rear locker and hte axles. The person installing it recomended i dont do the axles as they may cause issues to my rear crown wheel. They said your better to leave the standard axles and have them break instead of causing to much stress to the diff and potentially damaging the crown wheel on TDCI defenders.
    This person (dont want to mention who) also told me that the post 2012 110 and 130 pumas fitted with T/C have a thicker crown wheel in the P38 as apposed to previous models..once he looked up my model he said: "you have T/C fitted from factory so your crown is the thicker type, you will be fine"......"some of the earlier models have a thinner crown wheel".
    Has anyone heard this or throw some light on this being true or not?
    I would assume this person knows a thing or two about defenders as hes fitted plenty of rear lockers in them over the years
    Marty90 Guest
    Hi Nando,
    So a thicker CW means you'll be getting the HD axles? What's the point in getting a bullet proof diff and still have a weak point in the axles.
    Nov 2014
    Sydney NSW
    Hi Marty,
    That was my thinking.
    Until he looked up my model he was adamant that i should keep the standard axles. His theroy was that its a lot easier in the bush to rip out a busted axle and still be able to limp to somewhere for help as opposed to busting the crown and potentially being stuck with a busted rear diff.......this theroy does make sense but i wanted things to be as strong as possible.
    Free Again Thanks Dan
    Quote Originally Posted by 1nando View Post
    Hi Marty,
    In a deefer if you break a c/w just rip the axles out and drop the t/shaft off you go .
    By the way id do axles if your upgrading the centre to a locker . This theory of having a fuse in my opinion is flawed when all we want is a stronger diff axle combo setup . Whats the point if you only half do a job
    Sorry plenty of standard c/w and pinion`s with lockers and axles out there in realy tuff rovers
    I for one have and do run lockers with heavy duty axles and standard c/w and pinion`s. I have never had a problem if the diff is set up right . Mechanical sympathy is your best friend. Im thinking who ever you have chosen to do the job is not the right person sorry for such a job .
    Nov 2014
    Sydney NSW
    Hi Rangieman,
    I am doing the axles.
    He didnt want me to at first and then confirmed that mine had the thicker crown wheel and said it would be fine.....
    Im just finding it hard to believe that the pumas came out with different thicknesses of crown wheel's
    May 2006
    Woolgoolga
    I have read that when an axle snaps at the detroit end it can take out the detroit therefore everyone upgrades there axles.
    I'd doubt landrover would have 2 different thickness crownwheels as a factory option in the puma!
    They do have p38 type and normal rover type.
    Jun 2014
    Dubbo
    I reckon it makes sense to have a designed weak point. Its really no different to a shear pin in a piece of machinery to protect expensive, more difficult to replace parts.
    The drive flanges would be the ideal 'shear pin' in this case, nice and easy to replace, small enough to carry spares etc.
    NSW far north coast
    Quote Originally Posted by Beery View Post
    Naa, bugger that, I'd much rather have everything engineered and built so I never exceeded the fatigue and failure limits with what I do.
    FWIW KAM make two piece CV's and front stub axles with a machined groove to do what you suggest for comp vehicles where it is easy to exceed design limits.
    Jun 2014
    Dubbo
    Quote Originally Posted by rick130 View Post
    Yeah fair point. You'd have to spend some serious money on the drivetrain though, probably not an option for many people who might only one day be unlucky enough to over stress the driveline.
    That said, I'm considering 3 x Ashcroft ATB's this year haha
    NSW far north coast
    Yep, agree, it gets exxy and so I've spent some time slowly building things as I think they should be.
    Still haven't got to the front axle yet ! Thicker rear diff crown wheel on T/C puma?
    At least the rear end, unis, t/case and front driveshaft have all been rebuilt/replaced/upgraded to where I want them, just don't ask how long it's taken.......
    [Edit] oops, still have an upgrade to the Sals to go too. Have most all the bits, just other priorities over the last two years.....
