Results 1 to 10 of 21
Thread: Rear shock absorber
    Aug 2013
    Howrah, Tas
    Rear shock absorber
    Recently had car service and now have a leaking shock absorber. Has anyone replaced the shocks with heavy duty style and where to get them.
    Thanks landie56
    Sent from my GT-I9505 using AULRO mobile app
    Jason
    Range rover l322 2002 TD6
    Brisbane, Queensland
    I understood the shock for EAS is a different setup to standard suspension. Mine were replaced by the previous owner with OEM shocks. Mine were first replaced at 195,000km.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    NSW SW Slopes
    The CVDs are different but all non-CVD part numbers supersede to the 2009 (not 2010) non-CVD part numbers.
    For MY 2010 the only alternative is Bilstein and UK preference seems to be for genuine LR as they provide a more comfortable ride than the Bilstein replacement, but Bilsteins are cheaper and may be better if always loaded.
    Last edited by Graeme; 9th January 2016 at 10:53 AM. Reason: Corrected applicable year range
    Jan 2012
    Sunshine Coast, Australia
    I just replaced my rear socks last week. 195,000kms as well!!
    Seems like that's the time....
    I just used Britparts, didn't have the money for heavy duty upgrade.
    Aug 2010
    Sunbury, VIC
    230,000KM on mine - I had the shocks out the other week while doing everything else in the arse end, but the shocks were still fine. Guess they maybe on borrowed time.
    Easy job to do though.
    Are the shocks gas or oil? A lot easier job than on a Disco by the look.
    REMLR # 137
    Aug 2010
    Sunbury, VIC
    Yep, very easy. Based on my limited understanding of shocks - I'm saying gas - they push back out to their limits, and not stay collapsed. Is that right?
    NSW SW Slopes
    Probably only low pressure gas, not the high pressure of some after-market gas shocks. If the shock can be compressed by hand and it still works reasonably well then its not a "gas" shock. Konis have low pressure gas when new but when they're rebuilt they don't normally have any gas put back in.
    Aug 2010
    Sunbury, VIC
    As I said, I know nothing about shocks.
    I have no reason to suspect the shocks are aftermarket - the vehicle had just over 100,000KM when I got it so I doubt they had been replaced by the original owner.
    Jan 2012
    I drove around for a week without shocks in to diagnose the squeaks I was trying to get rid of.
    No problems at all.
    Felt a bit seasick at times though.......
