Results 1 to 6 of 6
Thread: Help with Puma Heater Bypass Valve
    Jan 2010
    I've got the puma heater bypass valve (pic attached below) but it is missing the clip/clamp that attaches the cable control to the lever.
    If anyone knows the part number for the cable/clamp or is kind enough to post a picture of how the cable control is attached that would be a great help.
    Cheers.
    n plus one Guest
    You can see the click in this shot - it's open and clips downwards over the actuating cable. Pretty sure the valve, mounting plate and clip are all one part number (but can't remember it off the top of my head).
    Hope this helps.
    n plus one Guest
    JQD500080
    Jan 2010
    Thanks for the photo n+1
    I've attached a photo of what I have.
    It's a brand new genuine part which I want to fit to my TDI.
    It has the cable securing clip but i'm not sure what I need to connect the control cable to the black lever that opens / shuts the valve.
    A photo of the cable attachment may help me track down the part number or happy with any ideas on how to attach.
    Cheers.
    n plus one Guest
    There you go.
    Jan 2010
    Perfection! Thanks a lot.
    Was searching for a clip, but can now see the attachment is part of the cable. Part number JFF500080 most likely.
    Excellent.
