Results 1 to 10 of 13
Thread: Traction control light
    Nov 2014
    Sydney NSW
    Hi guys,
    Long story but today i came into work to find one of the trucks had a flat battery.
    So i went and got out my jump leads and hooked them up to the truck and my dual battery in the back of my 110.
    The battery was pretty flat so i started reving the engine in my defender in neutral to create extra power. All of a sudden my t/c light started flashing on and off. As soon as i took the jump leads off it stopped and i cant get it to do it again. Is something wrong or what could it be?
    Only happen with the jumper leads on....
    Babs Guest
    Maybe the leads were slipping.
    Sorry I couldn't resist ha ha ha
    Sent from my iPhone using Forum Runner
    Nov 2014
    Sydney NSW
    Haha..
    I called my local mechanical centre and they reckon that it should not happen and ive got an issue
    Babs Guest
    $$$$$$$$$$$$$$$ Cha Ching. You have major problems book it in with us and we will fix it. Ha ha ha
    Unless it happens while your driving or happens again more frequent, I wouldn't worry.
    It could have something to do with a surge of power or could not, maybe just a coincidence, or a glitch. Wait it out or go test the TC in some slippery stuff.
    Williams West Aust
    Interested to know how you go about that.One of our CAT 12Ms has an electrical issue,if the operator hasnt isolated it we have to get the 24V isuzu service truck to jump start it.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jul 2009
    Andrew
    Andrew I actually think I read somewhere that the new 2018 Defender is going to be 24 volt so it can be used successfully to jump start real trucks without causing fault lights to come on. ...
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    Nov 2014
    Sydney NSW
    I sorted it out today with our auto elec.
    The way he set my dual battery means that i shouldnt be jump starting anything in the first place. Its set up to run all my auxilry things...
    I blew one of the fuses and caused the computer to go spastic. New fuse and circuit breaker and all sorted
    Jul 2009
    Did your auto electrician explain the difference between 12 volt Defenders and 24 volt trucks?
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D4 V8
    Jan 2014
    Perth Western Australia
    There seems to be an assumption that the truck is 24V
    Depending on if its a U.S, European or a Japanese truck, it could be either.
    Daz
    Jul 2009
    Yes I am assuming that it is 24v, because nothing has been said by the op to say it wasn't since this point was first raised.
    If it wasn't then fair enough.
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D4 V8
