Results 1 to 10 of 23
Thread: 300Tdi Power steering pump - how does it mount?
    Bracken Ridge, Qld
    Driving and suddenly squeals from the engine bay and alternator light comes on.
    Investigation shows that no tension on serpentine belt, and the power steering pump is flopping around like a fish in a bucket.
    Can anyone point me to an appropriate diagram showing how / where it is supposed to be secured, and what particular fasteners are required?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Bracken Ridge, Qld
    Here is the problem:
    [ame]http://youtu.be/1AJp7SuWLJA[/ame]
    Are these supposed to line up and have bolts in them or something?
    gone
    1996 Discovery 1
    current
    St Helena,Melbourne
    4.28 MB
    Yeah you appear to have lost a couple of bolts, the pump bolts to a bracket and that bracket bolts to the timing cover.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Bracken Ridge, Qld
    Any reference as to the parts I need to buy?
    gone
    1996 Discovery 1
    current
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by VladTepes View Post
    No but they are just bolts, take one of the existing ones out and match them.
    1974 VW Kombi bus
    Crafers West South Australia
    I don't remember exactly how the pump mounts up on the 300TDi but there may also be some bolts deep inside the alloy holder that the pump is sitting in. If the outside bolts fell out I'd definitely look closely once you've got the pulley off and the steel plate out of the way. From memory all the p/s mounting bolts are M8 by 20mm or thereabouts, LR use 10mm heads but normal 13mm ones should fit. A dab of Loctite on the bolts won't go astray.
    you appear to be missing at least 2 of the 3 mounting bolts that secure the pump to its mounting bracket. (video wont load for me ATM Im making the assumption off of just the photo)
    if you're lucky they have just worked their way out, if you're unlucky they have snapped.
    to replace them as is you will need to remove the pully from the pump and as the serpentine belt wont hold the pully for you you will need a filter strap to hold it while you undo the bolts.
    from memory the 2 bolts should be m8 1.25mm with a 30mm length. they are a shouldered bolt and are suspiciously exactly the same as the longer of the short bolts that hold your water pump in place (IE not the ones that go through the pump, housing, p gasket and into the block) as well as the bolts on your timing cover.
    Bracken Ridge, Qld
    I was hoping I could get away without removing the pulley - bugger eh.....
    gone
    1996 Discovery 1
    current
    Bracken Ridge, Qld
    While we're at it is it easy to remove the fan shroud?
    gone
    1996 Discovery 1
    current
    Safety Bay
    It is after removing the fan. Pat
