Results 1 to 9 of 9
Thread: Wheel threads
    Jul 2012
    ferntree gully australia
    Wheel threads
    Hi one and all , could someone please tell me what the thread size , and pattern of a wheel stud is . I have a damaged stud on my spare wheel carrier . All it needs to put it right is run a die down it . Before I can get a die , I would like to know the thread ! many thanks . Jim
    Apr 2012
    Endeavour Hills, Victoria
    G'day I just Googled it and I found: bolt pattern = 5 x 6.5" (165mm), stud size = 16 x 1.5.
    I hope this helps.
    Anyone else know anything different?
    Nathan.
    Normanhurst, NSW
    Quote Originally Posted by jimr1 View Post
    Defender or Disco ? As they are different diameters - 16mm & 14mm IIRC.
    Roger
    JDNSW's Avatar
    Seeing this is in the 90 110 130 Defender COunty thread, it is reasonable to assume that this is what it is for - and they are all the same, from the last of Series 2a to the last Defender - 16x1.5 as suggested, unless I am misremembering.
    Quote Originally Posted by Xtreme View Post
    Defender or Disco ? As they are different diameters - 16mm & 14mm IIRC.P
    16mm up to RRC & Disco 1 and Defender
    14mm thereafter
    Jul 2012
    Thanks John , yes a 110 . Jim
    Jul 2012
    Many thanks for your replies , I know that the stud size has been the same since the 2a , including RRC , and Disco 1 . So it is a 16mmX 1.5 mm Die that I have to get hold of . It should only take a few minutes to run it down the thread to bring it back to being good ! So once again many thanks . Jim
    MrLandy Guest
    New 2019 Defender or whatever, will probably be 12mm to match hilux. Or is that Hyundai?
    Jul 2012
    Quote Originally Posted by MrLandy View Post
    I can remember reading something about this a while back . I can't see the thinking behind this , but the people that do the designing seem to think it's a good idea . The original stud pattern was the same a Jeep . Jim...
