Results 1 to 10 of 13
Thread: Wheel nuts
    Mar 2016
    Katherine NT
    Wheel nuts
    I noticed a leaking hub seal on the left side of the 130 rear axle and a splash plate with snapped mounts on the other side so I might as well fix em up and give the bearings some love. So I go to crack the wheel nuts and wouldn't you know it their as tight as a nuns nasties ... I had no luck with the standard wheel brace , thought this is weird I know I haven't been to the gym but wow. I tried a cheater bar and started bending the wheel brace, at this point I'm scratching my head I was certain I was the last one to do up the nuts and even on a strong day I couldn't do it that tight ... Well after a 3/4" breaker bar and additional tube I got them cracked and still scratching my head I finally remember when I got the rear pinion seal and bearing done at a mechanic they used a .....rattle gun to do them up with.
    I would think that a diff specialist would be more aware of over torquing wheel nuts ,if I had a blow out between nsw and nt over Christmas I would have been in a world of hurt, so I guess this rant is just a reminder to throw a socket over your wheel nuts after any third party maintenance or pre trip . Rant over .
    Been there, fortunately only found it at home, not on the road!
    DAMINK Guest
    As a rule i dont let anyone touch my cars apart from myself.
    That said some things ya have no choice... Wheel alignments as one example and road worthies another.
    In both examples i have checked my wheels when i got home to find loose nuts.
    No kidding! Even worse than over tight ones.
    Most recent example of this was only a week or so ago when i got new tyres put on the wifes Jackaroo.
    Loose nuts yet again.
    Mar 2016
    Katherine NT
    Yea it's a pita
    Feb 2012
    Parkdale, Melbourne
    Yep, when I got my County back from RWC I couldn't get any of the nuts to move using a 1/2" rattle gun. None of them. I had nearly a metre long bar with my body weight on it to crack them. A few of the nuts have shiny grooves in them now. It makes me angry.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Jul 2014
    PERTH, WA
    Quote Originally Posted by Judo View Post
    Has anyone with this complaint actually tried telling the workshop / tyre place (BEFOREhand) the correct torque for the their wheel nuts?
    Seems like a common experience, and a reasonably sensible precaution to take, considering that.
    AndrewMilne
    Quote Originally Posted by AndrewMilne View Post
    AndrewMilne
    Last time it happened to me (new tyres) and I broke a 1/2" extension trying to undo them (used a borrowed 3/4" drive in the end) I phoned the tyre place and asked to talk to the owner. The next few times I was there I got apologies and they used a torque wrench and drew my attention to it. Unfortunately, the business has been sold and is now part of a chain, and I don't know anyone there any more, so when I am getting tyres or repairs, I watch them and pointedly ask what torque they are using.
    Feb 2012
    Parkdale, Melbourne
    I haven't, but next time I will definitely be asking before hand!
    - Justin
    Apr 2014
    Blair Athol, Adelaide South Aust.
    They obviously dont use those torque limiting extension socket thingys. Different colours for different torques.
    Cheers Rod
    Sent from my GT-I9507 using AULRO mobile app
    Sep 2010
    The Hills.
    152.79 MB
    All well and good, but I notice that, on the truck, they do them up first with a rattler and THEN use a torque wrench. Sure, then you know that they aren't loose, but you don't know if they're too tight. Lucky for me that I don't have to change them myself, because I can't.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
