Results 1 to 10 of 25
Thread: Flashing M & S
    bov17 Guest
    Flashing M & S
    Hi Everyone,
    Very new to Landrovers, my father and I just bought a Discovery2 2002 TD5 auto with 200k on the clock.
    Over all with the exception of a slight leak from the transfer case she is in great condition. With one exception.
    We have started to see the M & S and D(selected gear on the dash) lights flashing as well as the two red lights either side of the gear selector.
    Happens at random times, and I have done quite a bit of reading and have a couple of questions if someone may be able to answer?
    What size battery should we have in her? The voltage was 12.7 off, and 14.x running.
    Have checked the earths for the battery and they are clean and firm.
    We also unplugged and checked (what we think is the right thing) on top of the gear box actuator (but again, we are not 100% we checked the right thing here)
    What else should we be checking? After switching her off and back on it seems to clear and happily drive.
    We took her for her first off road experience on Sunday and went flawlessly however yesterday and today just driving to work, 3 times on a 40k drive here. and once on the way home yesterday.
    Not sure how to check the XYZ switch? When it is in reverse, put the windscreen wiper on and the rear turns on (even in limp mode)
    Your help would be greatly appreciated!
    Bacchus Marsh Vic.
    Welcome to AULRO.
    If M&S light only flash on the dash it's battery related, your reading looks fine.
    Your M&S lights include the ones on the selector so it's transmission related.
    My suggestion is to clean the XYZ switch as it could be water contaminated from the air conditioner drain tubes.
    Lots of information and links to the above repair in this thread...
    http://www.aulro.com/afvb/discovery-...-s-lights.html
    Also check the wire harnes where it goes over the top of the transmission.
    There have been a few cases of wires shorting due to the conduits be rubbed through.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    May 2015
    Williamstown, Victoria
    Quote Originally Posted by bov17 View Post
    The rear windscreen wiper does do that, easier to see out the rear window when reversing.
    Cheers and welcome
    Julian
    Build date 11th Oct 2003
    LROCV #1410
    Avoca Beach
    I recently had to disconnect the selector as I removed the floor of the console.
    The XYZ is properly adjusted when the dash indicator says the same as the selector, and the lights on the selector agree with the dash. I initially had mine a bit out but it literally fell into the correct adjustment when I loosened the jam nut.
    Regards Philip A
    bov17 Guest
    Thanks for the replies.
    Thanks Alien, Ill go through that page and see how we go.
    Will report back what happens :-)
    bov17 Guest
    Hi guys.
    Bit of a development. Well maybe.
    I have noticed just before the lights come on the d on the dash flashes slightly. Then again. The the green m and s lights come on and limp mode.
    Not sure if this is an indicator to the problem. Whitnessed this 4 times on the way home today. Somewhat frustrating off and on a bunch of times to get home haha.
    Sent from my LG-H815 using AULRO mobile app
    Road Stone Guest
    Hi,
    Does sound like its XYZ related. They are expensive too so the above suggestion of cleaning it is the first step.
    Low volts on the battery can also make this happen, I think N70 is the smallest battery you should have fitted?
    Cheers, Jerry
    Jul 2014
    west of Transylvania
    Watch carefully, are you certain that the flashing symbol is D not a crossed B?
    bov17 Guest
    Quote Originally Posted by sierrafery View Post
    I don't believe so no.
    Definately appeared to just flash flash then flash flash and green lights came on.
    bov17 Guest
    Will check out what battery I have now.
