Results 1 to 10 of 21
Thread: RRC ABS issue. Help please.
    Jan 2011
    Hi Everyone,
    I have a 94 softdash with a brake pedal that goes to the floor when it feels like it.
    I have bled the brakes following Rave. I used approx 2.5 ltrs of fluid and the brakes were good for about a minute. Mind you the vehicle was not driven at all. Its been on stands since I bought it.
    I can start the car up and the pump will run for approx 30 seconds and then shut off. I can hold my foot on the brake pedal for 15 seconds and the pedal will feel good. Then all of a sudden it slowly sinks to the ground. Lift my foot off and straight to the floor again. If I give it a few pumps the pedal goes firm again. It might be firm for a minute or so then the pedal sinks again. It cannot be driven in this state.
    When I was bleeding the system the manual says to bleed the lower front 4 nipples at the end of the bleeding process to bleed the master cylinder. What I found was I could bleed the inner nipple and eventually get all the air out. Then bleed the outer nipple. If I re checked the inner nipple the line was full of air again. This happened over and over again. Is it possible the master cylinder is sucking in air somewhere??
    Thank you.
    Jan 2012
    Bendigo
    Within the fluid reseviour there's a partition, and fluid must be on both sides of this.
    I've also had blockages at the bottom of the fluid reseviour that's restricted flow into the matter cylinder too...
    I can't be of much more help I'm sorry.
    Sent from my SM-G900I using AULRO mobile app
    Jul 2014
    west of Transylvania
    IMO you need a new master cylinder
    May 2006
    Woolgoolga
    Pull the abs unit out, place it in the bin, install vacuum booster and master cylinder😊
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by sierrafery View Post
    (X2)
    Feb 2013
    Ballarat,Vic,Aus
    This could be normal. Try it any modern car with ABS. My wife poogoe 407 brake pedal will slowly go to the floor if you apply constant pressure. Google it, it appears to be normal behaviour across a range of vehicle. Certainly it worried the crap out of me after I did brake work on the car (I'd never noticed it happens prior to that .... and had forgotten until you mentioned it above).
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Jan 2011
    Thanks everyone.
    So the t piece above the rear diff is now leaking plenty of brake fluid all over the diff. I will fix it this weekend and see if that's where the air was being sucked in.
    I hate abs and how it feels during emergency braking and off road but I'm if I can fix what's there without spending much money I will deal with it.
    I will check all the filters that can be cleaned as the fluid was very dirty. I will update after I've cleaned the filters, fixed the leak and re bled the system.
    Cheers.
    Nov 2014
    [QUOTE=DoubleChevron;2517988]This could be normal. Try it any modern car with ABS. My wife poogoe 407 brake pedal will slowly go to the floor if you apply constant pressure. Google it, it appears to be normal behaviour across a range of vehicle. Certainly it worried the crap out of me after I did brake work on the car (I'd never noticed it happens prior to that .... and had forgotten until you mentioned it above).
    This is not normal , I reckon your wife might want to take her car somewhere to get the brakes repaired , before she comes to grief, Google will probably tell you anything you want to hear depending on how you word it.
    Last edited by discorevy; 11th April 2016 at 10:44 PM. Reason: op posted answer while typing
    schuy1 Guest
    Quote Originally Posted by DoubleChevron View Post
    seeya,
    Shane L.
    That behavior is NOT normal. If thats happening there is something wrong. The ABS does not bleed off pressure, it only pulses a particular brake unit in response to slippage input. At all times there should be constant braking available, even without vacuum assist, albeit much more effort required . There may be a faulty ABS unit though.
    Cheers Scott
    Jan 2011
    This situation is definitely not normal. I can be sitting at the lights with a good pedal that has efficient stopping power then all of a sudden the pedal goes to the floor and the brakes don't work. The pedal might work well for 2 stops in crawling traffic and the the 3rd stop the pedal goes to the floor and the car barely stops.
    As I said earlier I'll update after I've fixed the leak and re bled it.
    Cheers.
