Results 1 to 10 of 14
Thread: MAP problem D3
    MAP problem D3
    Hi Guys, After seeing a thread just recently I decided to give my MAP sensor a clean. When I removed it from the electronic throttle body it was completely blocked. The hole it came out of was full of gunk so used a vacuum cleaner while I scratched away the gunk. Next came the sensor which cleaned up quite well my09 sensor has a 6mm hole so a lot bigger hole than in the earlier ones. I fitted the cleaned sensor and started the vehicle. A whole series of faults showed up including turbo transmission with a F in the instrument display connected the Nanocom cleared the faults but they wont go away. Unable to drive the vehicle as it has limited gears available. Seems to be a problem with the MAP sensor. Phoned up to get one from a dealership hope you are sitting down $720.00 . Does anyone know where I can get one a bit cheaper. The Boss is not very happy at the moment.
    They are about ?63 plus S&H from Rimmer in the UK but it will take a little while to get here.
    Thanks Andrew will get on to that. $720 bloody outrageous
    Many thanks again
    Mar 2012
    Gabbadah WA
    Surely the person who quoted that price must on drugs , or has made a big mistake in looking up the part .
    I rang the guy twice at Macarthur landrover as I thought he had made a mistake with which part I wanted but came back with the same result he told me to check ebay and other avenues as he told me it was over the top. Rimmer in UK $121Aud for genuine Land Rover we must have excessive taxes for it to be $720 in Australia
    NSW SW Slopes
    A few years ago I got one from the UK in about 4 days for my 3.0 (same as later 2.7) to get it faster than going through the warranty exercise, which I eventually did but without the inconvenience.
    Oct 2014
    MAP problem D3
    Or he quoted including the housing assembly it sits in perhaps? Check with roverlord as well (vendor on here). Mario got me a couple of spare sensors recently for good value.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Price was only for the sensor. My MAP sensor has nearly a 6 mm opening where all the others have a nipple with a small opening are all the D3 map sensors the same. I Have a LR part no from Rimmer in the Uk will have to check if its the same for my09 on Monday from the Dealers before or give Mario a ring. Thanks heaps guys for your feedback
    Smile
    New map sensor fitted car back to normal cleared all the logged faults and took for a test drive then checked for faults none to be found yippee the boss will be happy.
    Oct 2014
    Good result. Where'd you get it in the end and how much?
    D3 2005 V8 Petrol
