Results 1 to 10 of 21
Thread: Dual Battery rear bin.
    Feb 2013
    Adelaide
    I need to install a second battery and have decided to go with a rear bin install. Just wanted to ask if anyone can recommend what side to place the battery LHS or RHS? Mine is a 7 seater so I need to get a rear bin from a 5 seater either LHS or RHS to do the install. Thanks.
    Bairnsdale enjoying the rural view no rooftops to see here
    I used to have this in my previous d2 i fitted it on the rhs so that you only run the wiring down the same side as the main
    Sent from my SM-G900I using AULRO mobile app
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    Feb 2010
    I did the same thing with a 130ah battery in rear bin bit of modification but works well
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by Sleeping Wood View Post
    Do you have dual air conditioning on your 7 seater, as the evaporator and air con fittings are on the left side behind of that panel. If so you won't be able to use the left side.
    Regards, Mario
    May 2003
    On The Road
    You only have one choice,
    unless rear air con in a 7 seater wasnt standard---??
    Scouse?
    Adelaide SA
    Scouse?
    It wasn't.
    Mine never had it, and I had the "Town Classic" version of the D2a
    Perth WA 6149
    I'd be considering the left side, to put the weight opposite the driver and its marginally easier to get to with the door open. Agree though that the cable run would be shorter and simpler for the drivers side.
    Steve
    Feb 2013
    Adelaide
    Thanks for all the replies. I'm going to go with a RHS install. My car is a D2a classic, no aircon in the rear.
    Sent from my D5322 using AULRO mobile app
    May 2003
    On The Road
    Quote Originally Posted by Basil135 View Post
    It wasn't.
    how about that,,
    maybe a HSE thing then,,
    Apr 2015
    Rockhampton
    I am also abt to fit a slimline Kickass 120AH deep cycle battery into the rear RH bin.
    Can anyone advise the best route to supply power to the battery in the RH rear bin? I am assuming power is run from the VRS (mounted next to the front battery) along the top of chassis rail toward the rear, where is the best place to enter the rear of the body without any major modifications ... ie: are there any grommets available in this area?
    Secondly, can anyone advise the best method of securing the battery in this location.
    Cloughy
