Results 1 to 10 of 19
Thread: Rattling noise 2500RPM Disco2
    Mar 2016
    I have a distinct rattling noise in my 2000 D2 td5 that occurs at 2500RPM only in around 2nd or 3rd gear. I tried to record the noise to put onto youtube and link here whilst in the driveway today but discovered it doesn't occur in neutral or park at 2500RPM, only whilst driving.
    It sounds like its something just rattling around on the engine but now i know it doesnt occur while stationary it makes me think its something gear related.
    Is this a common thing for a 2.5 diesel 5cycl turbo? Ill try record it tomorrow while driving quickly as it happens consistently at that RPM. i either cruze lower RPM or go above it just to stop it, pretty irritating
    Nathan
    schuy1 Guest
    As you drive and when you hear it , ease the handbrake on lightly and see if it goes away. The shoes can rattle.
    Cheers Scott
    Mar 2016
    Ah ok ill try it out. What do you mean by the shoes cab rattle?
    Feb 2014
    Diamond Creek Victoria
    The parking brake shoes in the drum behind the TC
    Mar 2016
    Great ill try it tomorrow Thank you
    May 2003
    On The Road
    Gently!!
    Mar 2016
    Ok so i tried it gently on the way to work this morning and turns out my handbrake doesnt really engage so that cluld be the source of the issue. When i engaged whatever i could of the handbrake it did dampen the sound but not entirely remove it
    Is there a lot involved to re tighted then handbrake? I may have to give the mechanic another visit
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Delbs View Post
    There is adjustment on both the drum and in the cable, i think this came up recently so do a forum search.
    The other cause of a rattle in a TD5 is the harmonic balancer.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2013
    Augusta WA
    lrparts.ru/download.php?id=17 Follow this link for Tech Bulletin No.0022 on the handbrake rattle which may be useful.
    Nick
    Pennant Hills, Sydney
    Check that balancer mounted behind the park broke drum they have a habit of coming loose
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
