Thread: Front tow hitch on D4
    Aug 2015
    adelaide
    How strong is the front tow hitch/eye on the D4,is it good enough to snatch a fully loaded D4 or do I need to make/purchase a more robust item?
    Mar 2015
    Its strong enough, no extra point needed.
    Oct 2014
    See Gordon's summary in this thread: <Recovery Points>
    The centre points front and rear (behind the plastic covers) are for recovery, not tie-down. LR will not rate them (neither do any manufacturers), but the G4 team and LRE estimate them rated at twice GVM. We have been using them for 6 years on various cars for multiple recoveries (winch, tow, snatch) without issue.
    And this video has been shown on here before .... doesn't directly prove anything about the recover points as they used a lifting frame to the chassis but still a good demonstration.
    [ame="https://www.youtube.com/watch?v=3fufTUpi3FU"]https://www.youtube.com/watch?v=3fufTUpi3FU[/ame]
    Nov 2013
    Forestdale
    Also strong enough to pull out any fully loaded Landcruisers stuck in front of you
    Hope to never need it for my recovery, as long as "Rock Crawl" still working.
    Williams West Aust
    On our Horrocks fishing trip we saw a very similar to Aaron40s D4 in the same van park,it had a badly bent recovery point,must have tried recovering a tank????
    Not up there I bet they had it bogged to the eyeballs somewhere,we went close a few times.It was very soft.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jun 2010
    Central Coast NSW
    Andrew
    Could have been a poorly executed snatch recovery i.e. fly off at 100 miles and hour before the strap goes taught. Have seen that plenty on beaches.
    Dan
    Williams West Aust
    Yes seen lots of bravado from the pullers or ******* with huge lifted noisy non british recovery vehicles
    Andrew
    I managed to bend the one on my D3 to the point where I could no longer get a shackle on it. All I did was drop off an innocuous looking rock step on the Butcher Country track. The recovery point dropped on to a rock and it bent up to the cover plate on the ARB bar.
    So it can happen. I found it easier to trade it in on a D4 than straighten it.
    Jon
    Williams West Aust
    Interestingly if I remember correctly,this was bent downwards.So possible from a collision with mother earth.
    Andrew
    Feb 2009
    Quote Originally Posted by jon3950 View Post
    Jon
    Yeah and even if you straightened it you wouldn't want to assume it was safe to use.
    Do you know what's involved in replacing the point (other than changing cars?!)? I guess with an ARB bar you could use it instead anyway
    Sent from my SM-G900I using AULRO mobile app
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
