Results 1 to 10 of 25
Thread: Lockers
    Mar 2014
    New Zealand
    Lockers
    I have spent a long time reading through various posts (in other forums as well) on lockers. My initial thoughts was to install ARB on the rear and then when I could install them on the front. I already have a ARB twin compressor installed.
    Having done my research I am now wondering if this is the right choice, maybe Detroit True trac in the front & Ashcroft in the rear ?? Has anyone installed lockers in their Perenties and if so how have you found them?? Would do you do something different?
    Paul
    Jun 2014
    Waitakere, New Zealand
    Hey Paul, after having been involved in a few winch comps I will definitely be going selectable lockers in my 110. It can be difficult to get out of ruts with Auto/helical gear lockers among other things. Much more control when you can turn them off!
    I'll probably go Maxi Drive in the rear and undecided about the front just yet. They are on that long list of things to do...
    Hey you need a turbo, power steering and big mud tires before lockers
    Hay Point
    Detroit no spin in both rears and trutrac in the front in my 6x6.
    Cheers......Brian
    1985 110 V8 County
    Wheelers Hill, Melbourne
    Looking at how haggard my rear tyres have become since installing a Detroit, I am wondering if I did the right thing.
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Quote Originally Posted by Bearman View Post
    Hi Bearman, do you still have the 4.7 ratios in the 6x6 or have you changed them to 3.54?
    Cheers Rod
    Sent from my GT-I9507 using AULRO mobile app
    Hay Point
    Quote Originally Posted by 67hardtop View Post
    Cheers Rod
    Still 4.7 Rod, 3.5 is too high for them in standard engine form. I was contemplating using 4.1 and maybe using the RFSV transfer gearing but I don't thing the small difference would be worth the capital outlay for the Salisbury cw&p's in that ratio. Has anyone done a speed/rpm graph for the 3 ratios with .996 and 1.123
    Cheers......Brian
    1985 110 V8 County
    Apr 2014
    Hi bearman, if its possible do you still have the part numbers for the front trutrak and rear detroit and where you got them from and how much?
    Thank you.
    Pm me if u want to.
    Cheers Rod
    Hay Point
    Thank you.
    Pm me if u want to.
    Cheers Rod
    Rod I am away from home until Friday but will post up the part numbers then. I bought both rears s/hand off the forum here (they fit any ratio carrier) and the front is one I got from the AFM auctions with a stuffed cw&p. It is actually a 3.54 one but has a spacer to accommodate the 4.7 cw. Must have come from a LRPV I think. 912A407 is the part number
    Detroit 912A407 Truetrac Land Rover F 24 Spline Differential Drivetrain | eBay
    Cheers......Brian
    1985 110 V8 County
    Apr 2014
    Ok thanks Bearman. Im having trouble finding them and getting a correct part number will help me a lot. I have a salisbury in the rear of my s2a and standard in the front. I have both types of front axles 10 and 24 spline available to me to use. Thanks again.
    Cheers Rod
    Hay Point
    225SL36 are the rear ones - google is a marvellous thing!!!
    Filthy Motorsports Drivetrain Shop | Axle Parts, Lockers, and Gears
    Cheers......Brian
    1985 110 V8 County
