Results 1 to 8 of 8
Thread: Disco2 rim width
    May 2015
    Williamstown, Victoria
    Disco2 rim width
    Any one know what the rim width is?
    The tyre is a standard 235/70R16.
    I'm just wondering what the max size of tyres, muddies I can fit.
    also is profile 75 ok?
    Julian
    Build date 11th Oct 2003
    LROCV #1410
    Avoca Beach
    Rim width on D2 16 inch wheels is AFAIK always 7 inch.
    If the rims have been bought second hand be aware that 38A rims are 8 inch, as I found out by having to buy 255.70x16 rather than my preferred 245.75x16.
    It should be stamped on the rear of the rim .
    I have found on RRC and hoped to on D2 the ideal is 245.75x16
    Regards Philip A
    Oct 2007
    Brisbane West
    Just adding to Phillip I have had 235/70/16; 245/75/16 and 265/70/16 on my D2. I wouldnt go bigger than these larger sizes for what I do (ie 30.7 in or therabouts) even with my 4.6 high compression motor. I tow heavy loads and don't want it geared too high. I have a 2in lift and the just under 31in tyres look fine. Cheers
    Jun 2013
    Augusta WA
    Regards Philip A
    There is also an 8" X 16 option fitted to some D2's.
    Nick
    South Sydney
    Factory you had 4 options.
    16x7 steel (235/70-16)
    16x7 alloy (235/70-16)
    16x8 alloy (255/65-16)
    18x8 alloy (255/55-18)
    The biggest tyre you can fit without modification to the body is 265/75-16, and they need to be on standard offset wheels (+57), but be aware it will throw your gearing a good way out and make it a bit of a pig to drive (I threw 3k worth of diffs at it to counter this...).
    Mar 2007
    South Arm, Tasmania
    My D2 had 16x8 inch alloys, and it was only a "base" model, so they are not all that uncommon.
    Cheers .........
    BMKAL
    Oct 2007
    Brisbane West
    My base model had 16 inch steelies that I upgraded to 16 inch alloys.
    Mar 2009
    Port Stephens N.S.W
    My D2a came with 16x8 255/65 ... Classic Country Pack
    The 8" rims are marginal or too wide for 247/75 tires ... But 265/70 are the same diameter.
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
