Results 1 to 10 of 18
Thread: Rangie Suspension / Tyre Ideas
    Wilweld Guest
    Hi everyone. First post so here goes.
    I have an 85 hiline that I am doing up and we are up to the dreaded suspension and tyre phase. I'm trying to keep it fairly cheap and fairly tame to use as a daily, but I don't want to get left too far behind on the weekends either. All things to all men eh?
    I'm across all the "lift doesnt mean more tyre clearance" stuff, and I don't want wide tyres as I don't want to cut the guards but a bit bigger diameter would be good. I read on the lra website you need an inch body lift to clear 31s, but then you are looking at all the stuffing around that goes with that.
    So... after all that...
    How about a 2" spring lift, lower the bumpstops by 1" and maybe 235/85r16s on standard rims?
    Apr 2011
    Dungowan
    Lowered bumpstops would be a good idea. 31x10.5R15's on +13 offset rims rub on rear guard lips on mine. 1 inch bumpstop extension fixed that.
    235/85's on std rims rub on the rear of the front wheel arch on a mates RRC. Minor trimming would fix this i think.
    South Sydney
    2" lift and 235/85-16's on standard offset works really well.
    No need to do a body lift of extend bump stops unless you change the shocks.
    The tyres will rub on the rear door jambs but that's about it.
    That combo works really well in my experience...
    Eastern Suburbs, VIC
    For what is worth this was my old mans classic.
    2" lift
    31x10.5 on 0 or +10 ( was a while ago) sunnies.
    Only had to fold the lip over on the rear doors.
    1986 Range Rover Hiline
    2004 D2 TD5
    Perth WA
    PSI250 ... your old man's Rangie is sweet
    Agree with Rick1970 ....I had 31x 10.5 on my 2 Door classic with. 2in lift and had no issues with rubbing on guards ...tyres are reasonably cheap ther're equilivent to std 16 rims so no issues with speedo error.
    Ive put them on a recently purchased 92 Classic which has had the guards cut.
    92 had 16 inch alloys which I've put on the 2 dr while it's parked up awaiting engine transplant / rebuild as they were worn.
    I'll post photos of both later
    Baggy
    Dec 2014
    FNQ
    OK experts, answer me this...
    Why would you raise the suspension height by 2", if you could install a 2" body lift and achieve the same result, without significantly increasing the issues of CofG change and the subsequent change in diff pinion angles, caster etc...
    I can only think of one reason, $.
    Possibly 'easier' though I doubt it, as the additional work req'd with a suspension lift to maintain correct driveline operating angles is arguably more of a pita than lifting a body off a chassis.....
    I'm just wanting to understand what people's logic is.
    For me it would be pertinent to understand the reasoning for a decision, than to blindly follow without understanding what that reasoning is.
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
    Oct 2011
    Much easier to fit lifted springs than a body lift. Springs are very easy to change on a RR
    Body lift requires a hoist and you need to change quite a few bushes.
    Should also factor in that if the car is still on original springs, they would be sagging big time.
    Apr 2011
    Dungowan
    Quote Originally Posted by Mercguy View Post
    They don't achieve the same result. Pro's and con's for both i guess.
    Suspension lift can give some more compression room before it hits the bumpstops, if thats desirable. But may also loose some suspension droop, exp in the front of a landy. Also won't allow extra space for larger dia tyres without bumpstop spacing.
    Body lift alone may gain you some extra tyre room, but not much else.If suspension if left as is, your stuck with the factory stuff, which may or may not suit.
    Moderate sized tyres.....spring/shock/suspension to suit needs.
    Larger sized tyres.....suspension to suit + bodylift / guard cut to fit tyres at full compression without fouling.
    Make it as low as you can get away with, rather than as tall as you possibly can....
    South Sydney
    So when I hit speed bumps at 80km/h it doesn't bottom out!
    2" works quite nicely on these things, castor is only just becoming an issue.
    Chassis clearance doesn't hurt either, helps with approach and departure.
    Truth be told you don't need the lift, I ran mine stock height on 235/85's for several months.
    Dec 2014
    FNQ
    Quote Originally Posted by MR LR View Post
    That is interesting.
    Can you extrapolate a little? I'm curious about this, and what you had to do to the sheetmetal....
    I have a set of KM2's sitting under my house, and not used, mostly because a) they are on 16x8 ET-11 (so flares & cut req'd) I have the LRA bodylift waiting to be put in. I also have another set of standard 16x7 RRC rims, which I could fit the KM2's to - but haven't gone that way yet.
    I had plans to do a 3" spring lift, long travel dampers, and the body lift.
    I am reconsidering some of those available options.
    Being able to use the KM2's on standard suspension in the interim would be a good thing until I finally decide which way to go.
