Depending on your tyres and the conditions, deflat to say 20 psi.
Sand mode if it's soft. Turn off DSC. Every time you start the car or change the TR mode, TURN OFF DSC!
Other than that, go nuts.................and take some pics.
 Fossicker
						Fossicker
						Ok everyone I am about to embark on my first beach run going with a mate who done it before but neither of us have done it in a disco before.
Ok what's the list what do I need and what do I need to know all help is appreciated.
Zedrover
2011 HSE SDV6
 TopicToaster
						TopicToaster
17psi - sand mode - low range of it's really thick - it loves between 2-3000rpm - turn dsc off last . And yes check dsc is off every time you start or change tr modes.
And make sure you are at off road height,it will not work over 50k's/hr,and if you are going slower will drop down once you reach 50km/hr to normal height.Under 50km/hr it will work fine.Bongs and dash readout will let you know what it is doing.
If you don't go to off road height you may end up with a vehicle sitting on its belly
take a long handled shovel,it may be handy
As said,remember DSC off,each time you start the vehicle as it resets itself back on.
Tyre pressures down,sand mode,momentum is your friend in the soft stuff.
Have fun.
 Fossicker
						Fossicker
						Bring a long handle shovel...... A must have for any venture on the sand. At least you can dig yourself out if you manage to bury the car down to its belly. It happened to me a couple of times on my first outing on the sand at Stockton while I was trying to learn the ropes
Perhaps take along a pair of "MAXTRAX" or similar, should you get bogged they might prove useful.
Best recovery device is......
A pile of mates to dig / push
 Fossicker
						Fossicker
						If you re unsure of what you or the vehicle may be doing, I suggest that you invest a little bit of money and save yourself the potential for spending a lot of money if something goes wrong and sign up for a Sand Driving Course, preferably with someone who has experience with your Land Rover product.
If you would like to drop me a personal message, I would be happy to talk to you.
XDrive
