Results 1 to 10 of 18
Thread: Blown Front Suspension Airbag.
    Road Stone Guest
    Hi All,
    This happened to me this morning:
    Very fortunately, I was at the LR Indie at the time. He had just pressed the off road height and puff it went. A temp replacement put in from an old car and off I go.
    Also fortunately, I'm coming to Australia at the end of this week so would like to pick one up or two if my baggage allowance allows. I estimate 10kg a unit.
    The unit that came off is a Delphi 2223812 & marked RNB501260 it looks like the original given the date label on it, my car being a 2007 TDV8 L322.
    I'll be in Brisbane and Melbourne and would very much appreciate advice on where is the best place to get it/them?
    Thanks,
    Jerry
    Queensland
    Duckworth Parts in Uk - buy on line - ship to Brisbane; you can ship to me if you like - just PM me. It will save you a packet as I just discovered with my two rear shockies delivered to my door within 5 days ex UK at $999 for two v $2500 from Brisbane dealer.
    L405, Vogue SE, 4.4SDV8, 8 speed, Rear e-diff
    Road Stone Guest
    Wow great and thanks.
    Let me contact them first and find out what the GO is.
    Will PM you when I know.
    Cheers, Jerry
    Brisbane, Queensland
    That's kind of good luck. That failure is on the cards for both of us.
    I was looking around a couple of months ago as was thinking of a preemptive replacement. I found either Duckworths (Dan) or Island 4x4 was the best priced. Delphi seems to be the most recommended for a replacement.
    I found a place in Brisbane that sells a refurbed unit which reuses the shock. I would go Delphi especially with your location.
    Also I spoke to Bilstein Australia about their EAS. They no longer supply here as too many failures on Australian road conditions.
    Here are part numbers I found.
    LH Side RNB501550 LR032575 RNB501270
    RH Side: RNB501540 LR032566 RNB501260
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    I see yours failed at the very bottom of the bag. I concluded that mine still look at for now. But looking again I might be facing a split bag soon too.
    REMLR # 137
    Aug 2010
    Sunbury, VIC
    Yep, I got 2 new Delphi units delivered to my door for under a grand a few years ago from the UK - the exchange rate isn't quite as good now, but it was all under half the price I could get them for locally.
    I try to buy most of may parts locally, but the difference with these was too much to ignore.
    Jerry, in the AULRO Markets, Peter G has two brand new units for sale. He's in Geelong so getting them to Melbourne should be easy.
    But will they fit your model? Dunno.
    Feb 2014
    I had used island 4x4 in the uk. same price as mentioned earlier.
    Easy job to replace too
    Queensland
    rar110, can you tell me where in Brisbane I can get them rebuilt? I have two old ones now I could get redone as spares....
    This is their website. The do an exchange unit. From memory they did a US spec EAS, which they thought fitted ok. I was put off with reusing the strut.
    http://threepointclassic.com/parts/
    REMLR # 137
