Results 1 to 10 of 26
Thread: Odometer flashing
    Jul 2016
    Odometer flashing
    Hi I was wondering anyone can help me
    Discovery two the odometer is flashing I talked to a mechanic who connected to the computer he cleared several errors . One wouldn't go what wouldn't go away which says engines be has exceeded parameters or something like that any help
    would be great fully appreciated
    Oct 2007
    Brisbane West
    You can fix with Test book or Nano etc. I have gotten used to mine!
    May 2016
    nowra
    sounds like the odometer and bcm have different K`s on them , there is a setting in the nano that you can make the BCM not check the dash Kilometres , Your car maybe has had the dash swapped .
    Jan 2014
    Perth Western Australia
    As Rob has mentioned, the IP cluster has been changed out, it needs to be set with a diagnostic tool of some description...
    While thats a vague answer, beside the Land Rover diagnostic tool and the Snap-on tool (both of which will set the IP cluster) I've not used any other for that.
    Daz
    Daz
    May 2016
    nowra
    How many K`s has your car got ?
    Will be interesting as my ODO says 195,000 but BCM shows 293,000 ,,
    Another dodge from the seller
    Jul 2014
    west of Transylvania
    The "odometer error warning" must be disabled with dedicated tester in BCU settings that's all.
    as about that:
    IMO better find other mechanic
    Jul 2014
    Quote Originally Posted by rob tilbury
    ...BCM shows 293,000
    it's BCU not BCM , important is how do you know it shows that figure cos AFAIK there's no link between any tester ant that memory
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by DazzaTD5 View Post
    Nope. Mine did it all by itself, after I had the car about three years.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jul 2014
    It's possible if a speedo corrector was connected after the BCU.
    Jul 2016
    Thanks guys it has286000 on the clock so it's done a few
    It sounds like I need to take it to someone who specialises to figure it out
    Does anyone know of anyone I'm in rockdale area Sydney
    Thanks for the responses
