Thread: Fuel Tank Woes
    Sandgate, Brisbane
    Fuel Tank Woes
    I was trying to replace the fuel filler hose on Matilda & decided dropping the tank would make life a lot easier.
    Nope
    A picture paints a thousand words so I'll ask my questions & let them do the talking.
    How do I clean out this mess?
    Is there a way to replace the broken pickup fliter or should I just buy a new one?
    Looks like I need a replacement Fuel level sender as well.
    australia
    hi send your address and i will send you a piece jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    australia
    Quote Originally Posted by russellrovers View Post
    sorry fine stainless steel mesh
    Russell Rovers
    Phone 0428732001
    Sandgate, Brisbane
    Thanks very much Jim
    Jan 2013
    Molesworth,Tasmania
    seal up all the exits and then a good clean with caustic soda , then an even better rinse . The sender is available from the usual subjects - I think the Diesel version differs from the petrol in that it has an extra terminal for the low fuel warning light.
    cheers,
    D
    1957 88 Petrol (Chumlee)
    1960 88 Petrol (Darwin)
    1975 88 Diesel (Mutley)
    Sandgate, Brisbane
    So it doesn't look quite as bad now that it's dried out a bit.
    I thought it was full of flood dirt.
    So I turned it upside down & gave it a good shimmy & shake and this came out.
    Which ended up like this
    So i'm thinking I might do the Caustic soda/CLR/Vinegar thing & try some of that Red-Kote lining stuff.
    BTW. This is interesting to see inside a fuel tank.
    I wonder if it was made out of some scrap???
    Could be from Dullbird's place
    Sandgate, Brisbane
    So instead of mucking around trying to fix this in the limited time I seem to have these days, I dropped the tank to the HoHars for some Red-Kote lovin'.
    Came up pretty good
