Results 1 to 10 of 33
Thread: Discovery 2stereo upgrade
    Aug 2016
    Uk
    Hi guy, after much serching and not being able to find relevent infomation, i keep coming across this site and hopefully you can help me. I know this has been dealt with before but you guys are my last hope
    I have a landrover discovery 2 1998 ES with the Harmom Kardon high stereo, i have replaced the stereo with a "kenwood kdc-x7000dab"
    Now everything works, stalk controls ect ect, but i dont think it sounds as good as it should.
    this is the wires that im using "https://incartec.co.uk/landrover/1343/1033/2047/165/Browser.aspx"
    The problem i have is there is a hissing coming from the speakers, wasnt there before the HU swap.
    I have turned all the gains down on the amplifier integration interface, and whilst its still there its barely noticable.
    But if i remove the amplifier integration interface wiring it sounds so much better and how i would expect it to, but the hissing is terrible.
    Every time I try and investigate this I come across this website and this thread,
    http://www.aulro.com/afvb/discovery-...placement.html
    Which seems to suggest the the RCAs connect to the C0092 connection plug,
    Please can someone help me, otherwise I will have to go to an expert and admit defeat
    BTW I'm in the UK
    Cheers Neil
    Feb 2013
    Queensland
    Most amps have an earth loop in them if you have put youth RCA plugs in the wrong connections this will destroy the earth loop and give you a whine or a hissing noise from your speakers. If you have fitted every thing correctly then you can get from a good auto electrician a noise reducer that plugs between the amp and radio hope this helps.
    Jul 2010
    Hunter Valley NSW
    The factory amp connects to the RCA pre-outs at the new HU via the C0092. Dont use the new HU speaker outputs
    Aug 2013
    Rockhampton, QLD
    Quote Originally Posted by northiam View Post
    Have you done this? I only ask as when I fitted a new head unit it looked to me the factory amp ran from the high level outputs of the stock head unit. So I connected the new head units speaker outputs to the amp. It's been running like that for a couple of years now.
    Aug 2013
    Rockhampton, QLD
    Ok. So I looked at the link and its your post. Haha. Clearly you did. Interesting mine works without issue though....
    Jul 2010
    Hunter Valley NSW
    I did originally try the high level/speaker outputs to connect the amp and found really muffulled sound. Then tried the RCA outputs .
    The lower voltage of the low level(RCA) outputs should make the any humming less likely?
    May be yours would sound even better with the low level outputs?
    High-Level V.S. Low-Level Inputs | Learning Center | Sonic Electronix
    Jun 2016
    wa perth
    any audio leads running next to a power cables will cause interference
    or the stock amplifier doesn't have any filters
    Aug 2016
    Uk
    firstly thanks for the replys guys, this is far more help than ive had on this issue
    how did you do this, RCA to C0092, i have serched the net and cant find anything that would do this??
    The higher voltage of the low level(RCA) outputs should make the any humming less likely.
    yeah mine is a bit muffled, just doesent sound quite right
    Quote Originally Posted by geordiepride View Post
    im using the standard Land rover loom so i dont know if there are any filters or not
    Aug 2016
    Uk
    this is hows it wired at the moment
    Last edited by Tillytomp; 21st August 2016 at 11:22 PM. Reason: email notififcation
    Aug 2016
    Uk
    Right, i get it now, Now that ive joined i can see your pictures, did you make that adaptor, RCA to C0092.
