Thread: Front ABS Sensor
    Nov 2015
    Clyde North, Victoria
    Front ABS Sensor
    Afternoon
    I have a hard fault 3 amigos and my LR mechanic diagnosed this as a Front RHS abs sensor (came on after went through a few muddy puddles earlier this year
    He has a D2 for wrecking at the workshop and will try test that sensor in the truck. But if no luck on that, I've had a look on ebay for some aftermarket sensors (ranging price around $130).
    Can anyone share some input to these? should I stay away from them?
    '99 Discovery 2 TD5
    Kingston, Tassie, OZ.
    Do not use any aftermarket sensors . OEM Wabco branded ones are the go.
    Jc
    Nov 2015
    That's what I was thinking.. Anyways good news, am able to source a OEM sensor from my mechanic
    '99 Discovery 2 TD5
    cancerfour69 Guest
    Or do the three amigos bypass as described on YouTube uk..
    Sent from my jiayu S3+ using AULRO mobile app
    Sep 2009
    Option B doesn't fix a wheel sensor issue. Option B doesn't fix a wheel sensor issue. It is specifically to fix an issue with some abs modulators. If there isn't a fault in the modulator then why suggest an option B mod?
    Nov 2015
    Ended up being a front RH hub bearing and shorting abs sensor - getting the complete hub with sensor sent tomorrow.
    Atleast the 3 amigos hard fault will finally be fixed... until the LH goes
    $550 + labour for OEM hub bearing and sensor... also locally with 1 day turn around.. Not too shabby I thought
    '99 Discovery 2 TD5
    Jun 2013
    Augusta WA
    It may not be relevant but 5 years ago I had exactly the same problem RH front and was quoted a similar amount for hub replacement etc. I just removed the abs sensor cleaned the grease off the end and cleaned the connectors reinstalled and cancelled the codes with a newly purchased Hawkeye and not a problem since. What I saved by not having unnecessary work done paid for the diagnostic tool.
    But this is my experience with my issue and not necessarily yours.
    Nick
    Nov 2015
    Yeah we thought we could get away with that at first, tried it with no luck. But it was clear the abs was shorted and there was play in the bearing.
    I will order a replacement hub from paddocks next time, the OEM hub assembly are cheaper (freight incl)
    '99 Discovery 2 TD5
    Jul 2014
    west of Transylvania
    those so called OEM hubs are called so cos they are fitted with a wabco sensor but the bearing is poor quality, if you want something good(not cheap) better find a SKF dealer near you and go for the bearing assy without the flange(VKBA6753)...see this post: http://www.aulro.com/afvb/discovery-...uine-hubs.html
    Nov 2015
    Quote Originally Posted by sierrafery View Post
    Arrr legend! I will look into that in case the LH hub ever fails on me "touch wood"
    '99 Discovery 2 TD5
