Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Mixing engine oils?
    May 2015
    Williamstown, Victoria
    Mixing engine oils?
    I think it would be ok to mix Nulon diesel fully synthetic with Penrite diesel semi synthetic oil. Is it? Just making sure.
    I'm gearing up for the service.
    Bo
    Build date 11th Oct 2003
    LROCV #1410
    Jul 2014
    west of Transylvania
    IMO better not mix fully with semi, especially not different brands.... though if you mean drop one entirely and put the other no probs
    Free Again Thanks Dan
    Quote Originally Posted by sierrafery View Post
    X2 No .
    Oh a Simple Google got this for you
    What Happens if You Mix Regular and Synthetic Oil?
    May 2015
    Quote Originally Posted by rangieman View Post
    X2 No .
    Yeah but I looked for semi synthetic mixed with fully synthetic.
    Your google found Regular ie. mineral and synthetic.
    Bo
    LROCV #1410
    Quote Originally Posted by Bohica View Post
    Bo
    You asked and you got answered , It`s your car do what you want ,
    No more from me then good luck
    NSW far north coast
    The base oils aren't the issue, it's the dilution of the additive package that's a potential problem.
    In real world use you'll probably find no issue at all, but an engine oil is a finely balanced blend of base oils and additives, with the additive package accounting for up to 25% by volume of the oil.
    In some ways you could view it that the base oils are there merely as a carrier for the additive package. The mix of additives provide a lot of the Extreme Pressure (EP) and Anti Wear (AW) duties, anti scuff resistance, anti-oxidation duty, detergent and dispersant properties, etc.
    Put it this way, the resulting blend isn't going to start bubbling and frothing and smoking, nor is it going to suddenly breakdown and become like water, but you are potentially diluting the resulting additives which may or may not be similar and in similar ratios.
    It all depends who Nulon buy their add package through and then, which one they are using in that particular oil.
    Penrite have (or at least had) a very strong relationship with Lubrizol.
    I wouldn't sweat it too much if they meet the same specs and you aren't going to be towing a 32' monster van in 40*+ temps off road in low low while rock hopping.
    May 2015
    So it's out with the magnatec and in with the Nulon Fully Synthetic
    https://www.autobarn.com.au/full-syn...engine-oil-10l
    Bo
    LROCV #1410
    Oct 2007
    Wantabadgery, N.S.W.
    Very good to see Rick 130 back on deck. I hope you've been ok Rick.
    Don.
    Jan 2013
    WA
    value for money and high quality product, I couldn't top it.
    DELVAC 1 ESP 5W-40
    Cheers tt
    D2 2004 TD5 Classic
    Sep 2009
    Semi synthetic is up to 30% synthetic, so at least 70% mineral.
