Results 1 to 6 of 6
Thread: Fremantle - anyone local with a skylight manual opening tool?
    Oct 2011
    Fremantle WA
    Howdy folks.
    My special tool for manually turning the electric motor to open the roof/skylight has disappeared somewhere into the ether.
    Anyone reasonably local have one I can borrow or buy?
    I can't get the sliding sun panel out of its frame to get the entire headlining replaced (no roof electric wiring at the moment) - unless someone can tell me where/which wires to connect which way to a 12V battery to open the skylight without blowing/burning the motor?
    Cheers Gavin
    Apr 2015
    Hervey Bay
    G'day Gavin,
    I just using mine atm to make a replacement frame for the glass panel. By the look of it just a large flat blade screwdriver should do it. I'll check tonight when I get home. If not I'll measure it up if you want to make one.
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    Oct 2011
    Fremantle WA
    Many thanks, was hoping for something like that!
    Apr 2015
    Hervey Bay
    Hi Gav,
    Well you can use a large flat blade screwdriver in a pinch but it doesn't feel the best and I think it might damage the plastic keyhole. The proper tool feels so much better.
    Here are the dimensions:
    91 Kawasaki GPZ900R
    Gosnells
    . . . I know the feeling... not only vanished, but I've forgotten where mine vanished to....or from.
    Quote Originally Posted by gavinwibrow View Post
    Howdy folks.
    Cheers Gavin
    Oct 2011
    Fremantle WA
    Many thanks, but guess what. I was scratching around in the garage yesterday and "found" a small box of RRC parts I had put aside as being needed when I finally get to rebuilding - including the key.
    Now, I knew some bits and pieces had gone "missing", but I also know I didn't put them where I found them, and I'm the only male living here, with only one female. Conclusion!!!
    Anyway, tonight finally got the sunshade out and off to the headlining trimmers in the morning. Whoopee!
