Hi,
It is probably 1 tooth out on the spline, but I have no idea on how your steering wheel is removed.
I had a Dyna that had that issue, but I got a better view of the guages, so I left it.
Sent from my GT-N5110 using AULRO mobile app
 Master
						Supporter
						Master
						SupporterI have never done this with any car before but I've noticed my steering wheel is slightly off centre when driving straight.
Is this something you can fix yourself? I realise is inexpensive and in this case barely noticeable but thought I'd pose the question.
Hi,
 Master
						Supporter
						Master
						SupporterI'm fairly sure it's corrected under the car and has nothing to do with removing the steering wheel.. happy to be proven wrong though?!
It's more likely slightly off when driving due to road camber.
I also think it will be road camber related.
I have found that increasing the LH front caster by 1/2 degree corrects for this effect but I still notice a slight drift.
Someone else has had the caster increased by 3/4 degree but I haven't tried that.
http://www.aulro.com/afvb/l319-disco...-simple-3.html
Note that this is not something you do yourself, you request the wheel aligner to do it.
Link to my D4 Build Thread
D3 2005 V8 Petrol
 Master
						Supporter
						Master
						SupporterI'm certain it is more than just road camber, but I will find a flatter road and check on my way to lunch in a moment...
 ChatterBox
						Subscriber
						ChatterBox
						SubscriberYep , assuming the steering is off centre to the right slightly it could be road camber , if off to the left you have an alignment issue , when I worked in a Broome workshop years ago we used to get more than a few tourists wanting a wheel alignment because they noticed their wheel off centre and car pulling left usually starting around karratha , port hedland , I just took their vehicle for a drive and 9 times out of 10 told them to save their money , whether they believed me or not , who knows, but the roads north have a steeper camber to cope with wet season rains , as tombie mentioned find a quiet straight road except I'd straddle the middle of it and see if everything is straight then
